Home > Maintenance & Modifications > Water leak...
Page 1 of 3 123>
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
Water leak...
I have had this Defender for a month. Its a 110 TD5 2004 LHD.
Water (about 5cl?) comes out at the top of driver door near A-frame. From between the inner roof and the plastic seal (not rubber door seal). It also comes out on the outside above the rubber door seal. It only comes out when I reverse or corner sharply. The leak only occurs when it has been parked over night. Never while driving in rain.
I have studied the water ingress manual but fail to understand where the water enters or where it collects. Any ideas?
/Hans
Post #237899 22nd May 2013 10:55pm
Possible internal condensation on the interior of the roof? I have experienced some moisture with mine in the winter in similar areas but I put it down to that above as it's not like it all the time. If it was every time it rained it would be like it and it's not the case. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #237900 22nd May 2013 11:03pm
discoed
Defenders will leak - it's in their nature. You will be far happier if you just accept it and mop it up. With the construction and design used water leaks are inevitable.
In my old work 110 I had to keep a folder handy to deflect the water from the sunroof from landing on my head when leaving the yard - that was why I had waterproof seat covers! Rolling with laughter
Post #237904 22nd May 2013 11:10pm
Would it not have been better to have waterproof head protection? Whistle
Rolling with laughter ____\We|Will|Win/___
Post #237906 22nd May 2013 11:12pm
VeeTee
Netherlands
Probably leaking from the sunroof or alpine windows. It collects in the inner roof gutter and flows out wetting your knee when braking or sharp cornering. Guess how I know? Shocked Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #237907 22nd May 2013 11:14pm
discoed
It only happened once a trip - no justification for a waterproof hat Thumbs Up
Post #237908 22nd May 2013 11:14pm
HansT
No sun roof fitted and I have checked the inside gutter through the alpine window and it seems to be bone dry. Only dust... Can water follow the inner roof from alpine window all the way to front door?
So far I have ruled out condensation because of the amount of water.
/Hans
Post #237909 22nd May 2013 11:23pm
discoed
Yes
Post #237910 22nd May 2013 11:24pm
HansT
I will tape up the alpine window seal before next rain to test if this is the problem. Thanks.
/Hans
Post #237914 22nd May 2013 11:34pm
VeeTee
Netherlands
This might come in handy: Water Ingress Manual, see Process No. 2.5
Good luck Thumbs Up Cheers, Vincent
MySite
Post #237916 22nd May 2013 11:45pm
HansT
Yes VeeTee, this is about where the water comes out. But I want to know where it goes in as it happens when the vehicle is stationary.
/Hans
Post #237920 23rd May 2013 12:08am
JWL
Might be worth a look at whether you have a leak from the feed pipe to the rear wash wipe, yours is a left hand drive and the washer pipe runs (IIRC) in the channel where the roof meets the sides on the near side.
Post #237925 23rd May 2013 12:30am
also check,
> top of windscreen, where it meets the roof
> top of A pillars - should have sealant
Post #237937 23rd May 2013 7:01am
excossack
On mine, I found a gap where the roof drivers corner meets the A pillar. Resealed this and also resealed & replaced the Alpine window seal and applied plenty of sealant.
This caused the leak from standing. However, driving during heavy rain or parking at the wrong angle I still get water in. Looking at the roof there appears to be a bit of play (as in I can move the roof up and down a couple of mm, and I suspect as I am driving into heavy rain, the wind is pushing the roof up a little, opening the gap and allowing water in. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #237946 23rd May 2013 8:20am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Good luck Thumbs Up
Mine has a leak which drips on my right knee.
Thanks for the link I now know where to check and fix.
Post #238071 23rd May 2013 5:58pm
Page 1 of 3 123>
