![]() | Home > Puma (Tdci) > Intermittant loss of throttle response Puma 2.4 |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Could it be the age old problem of the Tdci reaching 110C and cutting out all power until it cools down again?
Mogboy Member Since: 22 May 2013 Location: Brisbane Posts: 31 ![]() ![]() ![]() |
Thanks Pope, but I don't think so, as it was running at normal, and only played up when I throttled back, and went to accelerate. I did have the overheat power cut back a few years ago, but nothing like that this time.
BarneyRubble Member Since: 08 Mar 2010 Location: Naphill Posts: 103 ![]() ![]() ![]() |
Not quite the same, but did have power loss whilst driving - turned out to be a loose relay connection under the drivers seat.
http://www.defender2.net/forum/topic7371.html Had LRA check it more than once without it being spotted, so be thorough and tighten all the spade connectors. Barney D4 - 2016 Graphite, Montalcino Red Written Off - 2010 90 Hard Top, Stornoway Grey |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20915 ![]() ![]() |
Not likely but it wasn't whilst warming up was it? ___\⭐️Lone|Star|State/___
____\We|Will|Win/___[/size] ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Hi Custom90steve
No...the engine was at full operating temperature each time. I've got a 2000km trip through some isolated areas next week, so hopefully if it plays up, I'll still be able to reboot/reset it OK. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Puma owner had the same/similar issue, turned out to be a punctured intercooler hose. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
deep down Member Since: 02 May 2012 Location: France Posts: 204 ![]() ![]() ![]() |
It sounds very similar to my problem, the relays under the seat had actually started to come out with all the recent vibration.
After re-seating them all I've had no more problems. |
New intercooler hoses here, Naks, so pretty sure it's not that.
Thanks Deepdown, I'll check that out for sure. I regularly drive plenty of rough dirt roads. |
HotelCharlie Member Since: 20 Oct 2011 Location: Kavala, Greece Posts: 25 ![]() ![]() ![]() |
Sorry to say, I got the same problem yesterday.
Upshifting 3rd, 4th and 5th, acceleration has a "hole" of a second or two before reving up normally. Happened after 10 minutes of driving in the city and for the rest of the trip. And nothing during all the following trips. Happy it has stopped, but I know something is wrong. <img> |
Splitpin Member Since: 07 May 2013 Location: Midlands Posts: 100 ![]() ![]() |
Maybe a sticking throttle body?
Or an intake air leak or egr issue |
I was told today by my local stealer that my problem comes from the EGR with fault code P1402 and P0403.
Only problem is this codes become normal when you get a remap with EGR electronicaly blocked like I have. And they offered to replace the EGR (of course!) speaking of a Technical Bulletin 300296 about a new EGR replacing mine!! Anybody got lights on this Tech Bulletin 300296, as I don't have access to Topix. Thanks <img> |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
Friend of mine had the same problem - turned out the head gasket was leaking........
Intercooler hoses do have a tendancy of chafing on the pulley/flywheel. Still worth a check.
![]() A few pointers perhaps? http://www.defender2.net/forum/topic9557.html?highlight=chafing 2.2 related but mine was chafed on my 2.4 http://www.defender2.net/forum/topic20804.html?highlight=rubbing If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17873 ![]() ![]() ![]() |
I don't see how this could be the case if you have a remap that disables the EGR. |
