Home > Technical > TD5 90 diff
markespark
2016 Defender 110 Puma 2.2 USW Indus Silver
TD5 90 diff
Hi, can I fit a rear diff from a 300tdi disco onto my 2003 TD5 90 ?
Or should I be concerned about gear ratios ?
Thanks Mark
Post #237587 21st May 2013 9:27pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Hi Mark
You should be able to use a Disco 300Tdi diff in your Defender,they are certainly the same ratio '3.54/1 they should also have the same number of splines for the shafts.IIRC you can swap the entire rear axle from one to the other. 2005 Td5 90 XS
Steve
Post #237601 21st May 2013 9:53pm
landy andy
As long as is 24 spline should be ok, but you may have to swap the input drive flange, some disco's were three bolt, and Defender's are four.
You got probs with yours?
Andy Thumbs Up
Post #237602 21st May 2013 9:54pm
markespark
My seals leaking like s**t I've checked the breather & it's ok, it's just that I've got another diff ready to go, mine seems to whine when I lift off so hoping to eliminate that ?
Post #237607 21st May 2013 9:56pm
Lou Sparts
It,s not leaking its just Land Rovers way of letting you know its not empty yet. 2005 Td5 90 XS
Steve
Post #237609 21st May 2013 10:00pm
markespark
Mines like me then goes about 10 times a night !
Post #237612 21st May 2013 10:01pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Depending on the exact age of the diff you are fitting and the diff you are removing you might need to replace some of the studs in the axle casing. Older diffs have a thin section where 4 of the studs go through, later diffs are the same thickness all the way round. It's really easy to change the studs but it's not something you want to find out when you put the diff in on a Sunday afternoon and need the motor on Monday morning. http://www.yorkshireoffroadclub.net/
Post #237620 21st May 2013 10:19pm
