![]() | Home > My Defender > The Yeoman DCPU |
YeomanOfTheBar Member Since: 04 Nov 2012 Location: North Notts Posts: 210 ![]() ![]() ![]() |
But on the upside, first box of goodies just arrived from Paddocks...
![]() ![]() Click image to enlarge 2013 Defender 110 XS DCPU |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076 ![]() ![]() |
I too have had some small paint issues
im replacing the windscreen blocks this weekend with genuine land rover parts but am going to prime and paint myself. im no spray paint expert but I think with a bit of care my spray job will last more than the two months land rovers attempt did. just part of the journey ![]() |
One for the suggestion box at the factory. From the amount of swarf I've found in mine it would make a tidy sum for them if collected in the scrap metal bin. Not surprised to find your paint cracked there - they do torque down those bolts for the canopy struts pretty tight. In fact so tight on a corner of mine it actually pulled the tub topside up a few mm ![]() |
First couple of modifications done this weekend. X-Defend first of all...
![]() Click image to enlarge ...followed by some new crystals with Osram Nightbreakers... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2013 Defender 110 XS DCPU |
Fitted a few FCX bits picked up from Matt at Billing - very pleased with the quality, and a top bloke too
![]() ![]() Click image to enlarge ![]() Click image to enlarge An the new Twin-DIN cubby - style fits perfectly with the factory XS trim... ![]() Click image to enlarge ![]() Click image to enlarge 2013 Defender 110 XS DCPU |
That looks fab
![]() May I use the pictures on our website please ? Thank you for the business ![]() |
You're very welcome ![]() Feel free to use those photos, although I'm planning on taking some more once I get home and using real camera (and have put the switches in and stuff) ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
A taste in two of the worlds most unreliable vehicles ![]() ![]() |
I was thinking 'a man with many problems in the making'
![]() looking great all the same.... especially the mods to date. |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
Those cupholders don't look much use!? Looking ace though Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
The one nearest the drivers seat can't be used but the other one is ok if the cup isn't too tall.
When fitted in a TD5 there's no clearance issues on either one. The cup holder is also removable leaving a rubber lined trinket tray |
Oh right, extra storage space is always good! The console does look fantastic! I have Fold down cup holders on the rear of the cubby, that may be an option.. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
TallPaul Member Since: 28 Aug 2007 Location: Nr Reading Posts: 270 ![]() ![]() |
As an Alfa/LR owner I can tell you Alfa have them beat hands down on reliability! 7 years in last Alfa: - one weeping seal on the clutch slave - £160 4 years in a Disco: new clutch - £1300 new suspension bushes EGR failures (Alfa also had EGR, no problem) - total failure both had to be recovered tailgate lock failed and had to be replaced handbrake adjusted 7 times and stuck on twice handbrake motor failed - £360 Air-con pipes rotted through and air-con died week before European tour - £700 Drivers door lock failed 100 other things I have mentally blanked out By an Alfa, you'll be stunned by the reliability if your a hard-core land rover fan! ![]() XS 110 Utility maybe one day..... (did they fix the quality yet?) |
And more on topic - cubby look good, what you going to mount in it? Disco 3 gone but the memory of the bills remain...
