![]() | Home > Technical > its (I've) been a bit quiet for a while now... |
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
Caterham, as you may have realised and without offence being caused what so ever. you have driven it like a fairy and it seems to get clogged up of which doesit no good what so ever
Get it hot on the motor way and give it this in 2nd, 3rd, 4th, and 5th oncein a while and it will free it up and keep the crid away Or bring it to me for a few hrs and ill free it up on the dyno no problem Pete |
[quote="Caterham"]
however I don't believe much more than 2250 rpm for 95% of the time is necessary quote] Where do you think peak torque is ??? Only reving it to this rpm is waisting power and wont help overall with the driving experience. |
| Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 672
Must admit mine is far better after 10k miles - far smoother
| Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468
Mine ticks over at 2250 rpm
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297
well despite using decent fuel, 2so, lots of Italian tune-ups, towing etc mine still has that tappety rattle on accelleration which has been there for 2 years now since I drove it home from the dealer. Trouble is it goes well, mpg is good and I'm beginning to think I should just leave it alone.
However we're on hols in Malvern again in July so its going into James French in Oxford for a proper checkup. I wish BAS and Alive weren't so far North ! Hopefully its just timing slightly out rather than a faulty injector. I can't see how it could be the latter as it goes so well Caterham just for a week drive like it like a knacker (the preferred term for pikey here) and see if it clears out the cobwebs ! |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
forgive me....
my wife knows only too well that I don't listen to good sound advice....... that said I still believe alot of my problems (too low revs) is the result of the my other problems and not the other way round. granted 2250 rpm might be a little low but I did suggest only for 95% of the time. I've seen my revs going up to best part of 3000 rpm without trying even trying recently while things have been running smoothly (especially in 1st / 2nd gear) and no matter what I won't be convinced that reving the engine beyond this regularly is advantageous ( so if only things were running smoothly all the time the engine would be breathing better but alais something is clearly not quite right and I'm still not sure if its the engine or transmission. (the only down side of the engine / transmission running smoothly is a reduced mpg but I'm more than happy to put up with that.) the clatter I've referred to in the past - if that was injecter clatter is it possible this could change from day to day - I guess not? I no I've been told otherwise but I'm still convinced the egr is causing a problem - sometimes I can be running along very smoothly at low revs (possibly too) low and other times under very similar circumstances there's a serious clatter sort of sound? the other thing is turn off and starting the engine. sometimes the engine stops smoothly with a wobble and other times its more a clunking sort of noise? starting is sometimes really eager and smother yet other times its considerably less so (I always wait for the glow plugs to go out) |
I would sell it if I was you and buy something more suitable .
the only thing I'd swap it for would be a cheap run about and an other Caterham but I'm not sure the wife wouldn't kill me.
+1 , it does seem you have had a lot of hassle with this car and I wonder if this particular defender is not what you need in your file any more. Pete |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Probably looks like this.....
Again without wishing to cause offence if you're not wishing to embrace information shared from those 'in the know' why not stop 'bleating' on in an open forum? Effectively it's just a spleen vent for your own benefit. There is just no helping some people! Treat every day as if it is your last....one day you will be right!! |
K9F is that an EGR and is it off a Defender ? And how on earth would it get that clogged up? How old is it ? Sure looks like a bad case
Hi Rossy, It's a picture from Dgardel's album. Maybe he could enlighten us. He, (as I will be soon) is running an EGR shut remap so it'll be immaterial. Treat every day as if it is your last....one day you will be right!! |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Caterham old chap, the convoluted machinations regarding your Defender are seemingly endless. Cakey is right but his suggestion that your Defender is probably not the vehicle for you has been made before, more than once Use it until something goes bang and get it fixed under warranty or ditch it ....but that has been suggested before ...more than once too Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
sorry guys ..... (and gals) didn't mean to ignore you (you're probably hoping I was
this email slipped under the radar. so it would appear I've been very wrong on various items and the egr being one - all beit very primative tests I'm confident the egr is working just fine. with / without a blanking plate fitted my 'issue' is still there. I can hear the chucka chucka sound and when reving the engine I can hear what sounds like the egr opening / closing? After having the turbo replaced and having done a few hundred miles I'm actually sure there is nothing what so ever wrong with the engine. The clatter is still there on / off but I believe its the transmission. Hopefully it can't be another dodgy gearbox to transfer box extension shaft but knowing who fitted it I wouldn't be suprised. I'm starting with replacing the transmission fluids and see where that takes me. ......may be this isn't the car for me........especially if how it is is normal. only problem is with all the issues I've had I don't feel I've had the opportunity to make a fair choice? ah well onwards and upwards. once again sorry for missing this post previously - hope you weren't thinking I'd 'got the hump and was ignoring your comments' as you may have guessed I'm a bit thick and things don't sink in very quickly.....so you need to mention things more than once....more than 6 or 7 times at least. |
| All times are GMT |
