Home > Maintenance & Modifications > Cor4 air intake |
macduff Member Since: 04 Nov 2012 Location: NE Posts: 117 |
A quick spin on the backside rolling road says its not any slower up hills but hard to say its faster. What was noticeable was its a lot smoother drive under 2k revs and quieter? I used to notice the egr chattering a lot on part throttle urban driving, and its seems to be either less egr activity or less noise directed in to cab . 2023 110 P400e
26th Apr 2013 11:27pm |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
An air intake cover can make any measurable difference on a defender. I don't believe that for a second.
27th Apr 2013 7:30am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6676 |
I agree Thud but I think you'll find it replaced a raised air intake in which case I'm sure there would be a noticeable difference
Love or hate the Cor4 design you have to admire these guys for their innovation and originality |
27th Apr 2013 7:46am |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
If a Mantek/JLR snorkle is removed to fit the wing vent it WILL make a difference for sure to power and its delivery. I have tested it on the dyno on several cars with shocking results. I dont know if a COR4 one is any better than the factory plastic wing vent but I for sure know removing the snorkle is. Click image to enlarge Pete Last edited by bell-auto-services on 27th Apr 2013 9:00am. Edited 1 time in total |
27th Apr 2013 8:57am |
I understand that removing the restrictive snorkel will show flow gains. I'm saying that a flash AI cover is no better than a boggo one.
27th Apr 2013 9:00am |
Prob very true on that note, they all prob do the same as the next just look different.
27th Apr 2013 9:01am |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 |
Since Pete remapped mine with a rai , it has lots of go uphill 47bhp more go
And if Pete was kinder to his customers mine would have a huge inter cooler by now I like mine it makes me feel rugged and its the only thing I will notice when it falls off Last edited by Cakey on 27th Apr 2013 9:30am. Edited 3 times in total |
27th Apr 2013 9:22am |
I don't doubt that, though I didn't have a stock placcy one, I didn't like the prices of the KBX? ones and following reports of the stock one being held on by a whim I wanted something slightly more permanent And as kindly pointed out by Pete of BAS it was replacing a RAI, that doesn't do anything useful in the climate/conditions its being used in that I can see (as it doesn't seal the intake from water ingress and I'm not likely to drive a dust cloud anytime soon) - so probably more a fashion accessory than the Cor4 plate that replaced it. 2023 110 P400e |
27th Apr 2013 9:23am |
As an added bonus, you'll never be short of somewhere to grate some cheese
Sorry, couldn't resist Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
27th Apr 2013 11:35am |
or open a bottle of beer |
27th Apr 2013 3:14pm |
rleslie Member Since: 10 May 2012 Location: Ellon, Aberdeenshire Posts: 128 |
Hey Mr Macduff, you never know when coming round from Tarlair you will need a raised air intake, and the dust clouds off the parks at Myrus!
Surly as long as it looks good and gives some performance gain (even in your own head) its worth it........ |
15th May 2013 2:05pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
What I was wondering is if you remove the intake pipe from where it goes into the air box would that be ok and you can keep your air intake on for bling
15th May 2013 6:30pm |
Maybe I've read it wrong but why and what benefits would be had? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
15th May 2013 6:49pm |
I'm assuming he's referring to the graph above with regards to the lower power. If you remove the intake pipe from air box, then in theory you could keep the snorkel for looks (if you like the look of them!), but not have the reduced power that they cause. I personally don't think it would work, as the air intake is on the outside of the vehicle for a reason. An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
15th May 2013 6:56pm |
