Home > Td5 > Fuel Pressure Regulator: cheap fix?
DC101
United Kingdom 2005 Defender 110 Td5 CSW Zambezi Silver
Hi,
My fuel pressure regulator has started to leak on my 2003 110 TD5. A complete replacement unit with pipes etc would cost about �130.
However, I have seen on e-bay the main part of the regulator unit that I understand usually causes the offence for around �25 (rated to 4 bar). I was wondering about purchasing this and marrying it upto some OE landrover o-rings and gaskets for a satisfactory fix. Comments please!
Cheers,
Rob
Post #235698 15th May 2013 1:06pm
ajps72
2001 Defender 110 Td5 SW Chawton White
Re: Fuel Pressure Regulator: cheap fix?
If the leaking is only going out, and there is no pressure loss (no power loss) then the Orings will do the trick, but buy the best ones. cheap ones will not last. Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #235716 15th May 2013 1:47pm
jst
last regulator i had complete was �60 ish, is your price gen?
yes its a easy job to do Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #235737 15th May 2013 2:28pm
DC101
After calling around, the price I have seems fairly standard for a complete unit.
Hence I'm wondering whether this eBay valve I've seen for �25 is of use?
ajps72 - no loss of power noted, thanks for the tip.
Rob
Post #235763 15th May 2013 3:20pm
SGH
Rob
Break down of parts are in pdf in my gallery
Simon
Post #235767 15th May 2013 3:38pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
viton o ring
make shore you use viton o ring or may regret can be sorted in line
Post #235903 15th May 2013 9:06pm
DC101
Thanks Simon. The part advertised on eBay appears to have no assigned number on your PDF file. It sits just to the left of the number 13!
Excuse my ignorance but what's a viton o ring?
Cheers,
Rob
Post #235930 15th May 2013 10:13pm
dorstsmith2
viton o ring used on TD5 fuel pressure regulator by LR
Post #235937 15th May 2013 10:30pm
DC101
Many thanks for the info.
Rob
Post #236098 16th May 2013 4:48pm
