Home > Maintenance & Modifications > Power to a camping trailer
pjh
Hi,
I'm building our Sankey camping trailer and I've installed 2x Optima yellow top batteries. I wondered what recommendations forum members had for charging them from the LR whilst on the move. My thinking is to use decent (10mm) cable and a 50amp Anderson connector, any other recommendations?
Kind regards,
Peter Defender 11MY USW
Post #235077 13th May 2013 12:09am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Why not just use the power via the normal trailer connector? I have a 110hr battery in the tin tent that charges that way no problem. I think you might need a 12 pin socket for that though (although not an expert Very Happy ) easily fitted to existing wiring by the looks of it . I got someone to fit that for me but there are a few posts on here about the conversion. - kits available to do it.
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #235081 13th May 2013 1:02am
BigRuss
anderson connectors? Russell
2011MY 110 XS USW Black
Post #235082 13th May 2013 3:21am
Splitpin
If it was me I would use the standard caravan charge output.
I personally like to charge a slow rates and a thin long supply cable will regulate this well.
I would add some solar panels on the top of the trailer if possible as on a good day they
work very well, but for me the key thing is, even if the trailer is left unused for sometime the battery will be topped up and it will last longer if kept in that condition.
Post #235093 13th May 2013 7:38am
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
When I built my trailor I used a 12s charger it also had the advantage of giving me a reverse light. The genuine 12 s kits are available on eBay for around 50 .
http://forums.lr4x4.com/index.php?showtopic=49598
I fitted the electrics from a caravan and boat and kept it all 12v except fo a 800w inverter, I find this wastes less energy as you are not converting things both ways. I also added a 240v hookup with a caravan charger/power supply when we are at home on a camp site this allows us to charge the batteries prior to our trips and run the fridge up to temp without having to worry about battery drain.
Jason
Post #235097 13th May 2013 7:59am
Another vote for using a standard caravan charging set-up - either 7 pin 12s or later 13 pin socket. Even the Desert Wolf trailer that I used to have, with two 110amp batteries on board, worked perfectly like this. Darren
Post #235099 13th May 2013 8:23am
ericvv
I just added a 12S 7-pin socket in addition to the standard 12N 7-pin trailer socket. The 12S gives permanent connection to the truck's battery, and also gives the flexibility to easily connect a Ctek charger to the main battery without having to take out the seat bottom. If you use the site's search engine with "Ctek" you will get a recent started thread about this with pictures of how it all looks in the back. Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #235172 13th May 2013 2:47pm
pjh
Thanks everyone!
Eric that's a very neat solution. My problem is that I installed a standard 12N socket in the cross-member recess and then had an additional fuel tank installed in the rear wing, so access to the connectors is very difficult if not impossible. Otherwise I probably would go down the 12S (auxiliary) socket route.
I might install a higher rated feed with a voltage sensitive relay in the trailer - I don't want to drain the truck battery when on the Santander ferry!
Anyone know how the purpose built off-road trailers solve this problem - esp those with fridge/freezers?
Many thanks,
Post #235832 15th May 2013 5:41pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
run cables from a relay (use the winch relay if you have one) to the rear and make it switchable both on an ignition feed and switch.
That way you can never leave them connected with the engine off and you can select when to join if you have low battery on the truck when starting off. You dont need fancy voltage sensitive controllers.
Take all that to an anderson plug at the back and off you go.
Time for coffee!
CC
Post #235839 15th May 2013 6:14pm
pjh
Chopcat, thanks for the advice, much appreciated.
That's a very nice set-up. Just don't let Kiwi Girl see that!! Smile
All the best,
Post #235847 15th May 2013 6:34pm
K9F
pjh wrote:
I don't want to drain the truck battery when on the Santander ferry! Anyone know how the purpose built off-road trailers solve this problem - esp those with fridge/freezers? Many thanks, Peter
I work on Condor Ferries and anyone in that position with an auxillary single phase 230v/32amp (blue) or indeed in some cases 3 phase 415v/63amp (red) connector can request to be connected to the vessel's 'Reefer Supply' with a trailing lead supplied by the vessel thereby still run everything whilst under sail. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #235854 15th May 2013 6:54pm
pjh
K9F - many thanks, I'd no idea that was possible Thumbs Up
All the best,
Post #236302 17th May 2013 12:37pm
udderlyoffroad
In your position I'd think seriously about replacing the 12n socket in your rear cross-member with a the new 13-pin style connection. When wired properly this will power your aux batteries with the ignition on and not flatten your main battery whilst on the ferry.
In addition, the 13-pin style connection is, iMHO, an improvement on the previous 12N/S sockets with better mechanical lock.
What I would definitely NOT do is run an Anderson connector wired permanently to the trailer. Although the design of the Anderson is good, is not designed for permanent connection in an exposed environment and I would worry about a dunking shorting the connection out (even with a protective boot+front cover). Real trucks don't have spark plugs
Post #236477 17th May 2013 11:06pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
If it's dry I will be fitting my 13pin socket although I haven't picked up a voltage sensitive relay yet so the ignition on feed will have to wait. The permanent live and reverse wires are already on the standard plug.
I'm hoping to re-use the original cable from the sankey with a new 13pin plug. www.td5.org
Post #236731 18th May 2013 10:58pm
I've done this twice now with a 13 pin plug. On my first Wide Track I grafted the plug onto the end of the existing cable, which was a bit of a challenge frankly, due to the thickness of the cable. I made it work by cutting off all of the really unnecessary wires to just get the lights working.
On my current Wide Track I've taken a different approach and created a junction box that's bolted to the A frame, using the mountings for the original plug 'keep'. This makes it much easier to sort out the wiring conversion and allows a more sensible cable size to be used with the new 13 pin plug.
Eventually, i'll be re-wiring my trailer anyway, as I plan to change the lights and add some camping-orientated extras. These will make full use of the 13 pin plug in the same way that a caravan does. Darren
Post #236775 19th May 2013 9:44am
