![]() | Home > Maintenance & Modifications > Fitting a check temp sensor |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
the relay of the CheckTemp must be connected to the pin 4 of the C0275 Defender connector (Aircon ON/OFF) CheckTemp installation scheme
LR scheme
LR connector library In this way you turn-ON the A/C and the CheckTemp A/C function: now the CheckTemp will manage the internal Temperature like you request (Check temp stored value) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated
IID Pro MV License |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Thanks guys
This is pretty much the last connection I need to make on the FCX 130 dash and identified the switch circuit on the A/C switch but couldn't put my hands on the Checktemp instructions |
No problem my friend
https://www.defender2.net/gallery/albums/u..._fr_es.pdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
Excellent !
Thank you dgardel |
| muddypaws Member Since: 22 Jan 2013 Location: Leicestershire Posts: 122
Well, another successful installation of this excellent product, (bought off Amazon)
A massive thank you to all those useful posts before without which I may not have attempted it. Just a few additions to make it even easier for any doubters!! 1) It is quite a 'manly pull' to remove the fascia -I didn't need to unplug the clock 2) If siting the display high to the side of the steering wheel, put masking tape on the wheel itself as it is easy to catch it with the file. 3) The plastic dash is sl too thick for the retaining clips of the display surround so file diagonally to thin them and it sites beautifully 4) If you remove the plastic moulding just above the steering wheel, you can just see the large oval grommet taking the main loom to the engine bay. A knitting needle pushed through from the engine bay can then be used to draw the outside sensor wire back through into the engine bay. It is a double grommet so be patient and expect to feel it go through a second resistance! 5) Tape sensor wire to loom on wing and I dropped it down behind the radiator grill which I removed to site the sensor itself. 6) Inner sensor easy to locate on dash at bottom right as shown previously Job done -about 1 hour for electrics, 1 hour for filing and 1.5 hours for the outer sensor (but I did stop for 2 cuppas in that time too All I need to do now is work out the German instructions to set the clock!! Thanks again to those before me!! Richard Defender 90 SVX |
| martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422
Well theres another thing to add to the list of ideas, I`am gonna be doing over time just to pay for the extras, well less caviar for tea !!!
Not a stupid price -£65 from Amazon if I recall
Ah just seen -another Leicestershire fellow!! Richard Defender 90 SVX |
Well if I see dodging in and out of the new bus lanes on lutterworth road I`ll wave. And if your not from Leicester heres how to waste 3 million quid to save 3mins from one part of town to another..
| Xelr8 Member Since: 26 Aug 2014 Location: Sheffield Posts: 165
Old thread I know
But assuming alls ok wi mi motor then I think I'll be another for this Mod |
Yes - all is fine
Only sl mod would be not to site the internal sensor as close to the heater but would route to another location Richard Defender 90 SVX |
| Jamie W Member Since: 28 Mar 2012 Location: Herts Posts: 32
Just fitted one of these units, I wanted one for a while but just could not bring myself to cut the dash to fit it. Eventually I gave in and purchased one.
Thanks to all those who posted their comments and fitting instructions- this made the whole thing very painless indeed!!! purchased from amazon at a reasonable price for what is a good quality and accurate bit of kit- looks factory fit! |
| Furball Member Since: 31 Jan 2016 Location: Wiltshire Posts: 42
This is very helpful thread, thanks to contributors. JB.
Jamie, please could you share the amazon link. I want to order one of these and can't find it on amazon. Thanks, JB
Difficult to find on amazon but this is the chappie
http://www.amazon.co.uk/in-pro-10330-in-pr...pro.+10330 Richard Defender 90 SVX |
