Home > 130 > Quadtech body's
Juddy
Australia 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Quadtech body's
Are these made from wood. 2010 Defender 130 HCPU
1991 110 RFSV PERENTIE
www.landybitz.com.au
Post #234570 11th May 2013 9:39am
K9F
Link would have been handy.... Whistle
Quick Google on your behalf reveals....
"Later construction with alloy frame and composite panels."
So I would surmise depends on how old it is....
Couple of links:
http://www.ebay.co.uk/itm/Land-Rover-Defen...1c2bdcc86e
http://www.landroveraddict.com/forums/thre...;boardID=3 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #234574 11th May 2013 10:05am
Juddy
Thanks
I have no idea how old it is but it looks like its all made of wood, with the alloy supports.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2010 Defender 130 HCPU
Post #234582 11th May 2013 10:36am
GUM97
I think it's fair to say that the one above it made of wood! Thumbs Up An engine to TDi for!
Post #234605 11th May 2013 12:27pm
ickle
Wisacon???
(phenolic coated marine ply)
Post #234726 11th May 2013 8:20pm
Killer90
Site Sponsor
Its a certain type of wood, it has a smooth texture on both interior and exterior i think ickle got it Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #234729 11th May 2013 8:24pm
Juddy
ok jokes aside, what wood is it made of of? 2010 Defender 130 HCPU
Post #234833 12th May 2013 10:59am
K9F
Killer90 wrote:
Its a certain type of wood, Thumbs Up
^^^^ Why? Not necessarily. You need to ask the seller as looking at the pictures tells you nowt or go have a look up close if possible to see if it's crossweaved. Thumbs Up
Phenolic board is not made of wood - so nothing to rot its made of woven fabric that's pressure and pressed with phenolic resin under huge pressure, and is nigh on indestructable - attack a bit of ply with and axe it'll go through. with PB it'll bounce off
it never rots, is immune to UV so doesn't breakdown that way either and is resistant to almost all petrochemicals, it's fireproof as well so almost indestructable" If you go through life with your head in the sand....all people will see is an ar5e!!
Post #234837 12th May 2013 11:11am
Juddy
Thank you, I now understand what wood this is.. 2010 Defender 130 HCPU
Post #234840 12th May 2013 11:20am
K9F
But it may not be 'wood' at all? Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #234841 12th May 2013 11:21am
Juddy
well wood kind of. 2010 Defender 130 HCPU
Post #234842 12th May 2013 11:22am
K9F
Juddy wrote:
well wood kind of.
Post #234846 12th May 2013 11:38am
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
That my friend is fibreglass coated marine ply, so yes it is wood with a coat of fibreglass on either side. This is the material of choice for 99.9% of coach builders for body construction, Phenolic Plywood is almost always used for vehicle flooring due to the cost and difficulties when painting. Thumbs Up Thumbs Up Thumbs Up You only have one life, live it....forget the cost.
90XS Hardtop
Post #234850 12th May 2013 12:09pm
ickle
As an apprentice, we used to make all kinds of fire engines from Wisacon, I think its a larch marine ply with a phenolic coating, I can't remember any grp strands when cut, and it took a paint finish really well.
I also made horseboxes out of similar stuff, and there are a huge amount of trucks on the road from the same.
Edges had to be sealed with a grey rubbery paint, & damaged exposed edges will rot.
I think another firm sent a load of fire & rescue trucks to Africa built from a Wisacon type material in the late 70's - apparently the local termite population did a very good job of lightening the construction somewhat!
Keith
Post #234860 12th May 2013 12:49pm
roamingman
Mine has steel frame wood on inside alloy and steel out side,
see gallery. Smile Live Life Ti'l You Die
Teddys are out thier
http://teddybearspicnic.webs.com
http://130sasha.co.uk/
Post #234889 12th May 2013 3:41pm
