Home > Td5 > Td5 issues
Page 2 of 2 <12
Laurie
Maybe worth looking at the inside of the flexible air hoses.
Has been known for them to delaminate and alter the aiflow.
Post #234413 10th May 2013 6:24pm
landy andy
Nick T wrote:
Mine is the same. Safari snorkel etc.. Done all the usual suspects. Can be dangerously slow at pulling out in traffic-then goes like a flying machine????
This sounds like classic MAF failure to me. Put your foot down, nothing, then whoosh, your off.
I only run alive unrated MAF's now, and have only knackered one of those with water ingress Whistle
Andy
Post #234563 11th May 2013 9:05am
landyman37
Had a similar problem with our disco 2 seemed to be lacking power on certain days. Recently fitted a new fuel pump (genuine one non genuine fuel gauges don't register right) just pulled our caravan to north Yorkshire what a difference it's made.
Phil
Post #234573 11th May 2013 10:01am
Nick T
England 2010 Defender 90 Puma 2.4 HT Galway Green
Andy
I've replaced the MAF-didn't cure problem. The fuel pressure has also been checked Sad
Post #234579 11th May 2013 10:26am
adseybear
Canada
Lately when the engine is cold at low rpms when the turbo spools up, it makes quite a loud whistle if this could possibly be related. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #234583 11th May 2013 10:41am
barbel jim
most turbo's do that, again to do with air density Wink
Have you checked all your Turbo pipes yet ??? Early TD5 Delaminated as Laurie says, and I still tink you could have an intermitten leak on the charge side Wink
Post #234608 11th May 2013 12:44pm
adseybear
Canada
I'm trying to make plans to get either BAS or Alive to take a look as they should know what a healthy Td5 should drive like, I'll keep you all updated. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #234611 11th May 2013 12:57pm
adseybear
Canada
As you may have seen, I've had the remap done, Alive checked everything and all seems in order.
The only possible culprit we can see left that could be causing this mysterious sometimes power loss, is a collapsing cat. She's run lovely for the last few weeks, so if it comes back, a decat pipe will be going on. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #238531 25th May 2013 12:13pm
THF
United Kingdom 2004 Defender 110 Td5 XS CSW Oslo Blue
Been watching this thread with interest, as I too am not running right and have seen a drop in MPG & performance over the last 4k miles. (I've been monitoring it on a MPG app).
Car is now running at about 20mpg, Sad nearer 23 at the beginning of year, and 350 miles out of a tank last year. How do you know the MAF sensor is duff, I've run it for about 20miles unplugged and can't really notice any real change. Heading back home next weekend, so I'll get the local Indy to run a diagnosis check on it, then look at replacing it. Anything else I should be thinking of?
Once that is done, its blank EGR, off CAT and then time for a remap. Very Happy
Will continue to watch and keep updated.
Post #238693 26th May 2013 2:48pm
Drop in MPG and performance usually points to the MAF.
Usually if you unplug it you'll notice an improvement, but when mine went, it didn't seem to make any difference.
If your local has a plug in diagnostic machine, nanocom or whatever, you can read the output from the MAF and see if it's knackered or not. takes minutes, if that.
Post #238744 26th May 2013 7:31pm
THF
Interestingly, after my 20 miles running with the MAF unplugged, I plugged it on for the trip home (250miles). Laden with kit, bike on a towbar bike rack and cruising at motor way speeds (+/-10%) Whistle its managed a happier 23.8 MPG, with a bit more grunt than before. Not sure of the unplugged woke the MAF up as it was reconnected. Confused
Visit to the Indy for a dianostics check next week should clarify more.
Post #239981 31st May 2013 2:46pm
Could just be a crappy connection on it.... the MAF on my project90 came up as duff with nanocom plugged in, so i bought a new one, checked it again and it was working! (after being unplugged a couple of times)
Post #239983 31st May 2013 2:56pm
Laurie
I'm having the same connector problems with the MAF on my 3.9 V8 in the Dakar.
It's got a couple of cable ties pulling it tight at the moment.
Post #239991 31st May 2013 4:20pm
Page 2 of 2 <12
