Home > Puma (Tdci) > Remap and noises after engine shutdown.
Page 3 of 4 <1234>
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
i do admire the fact that there are people who develop engines to produce more power/torque than the original manufacturers, but we must all remember that LR still spend an awful lot of money developing the Defender, regardless of what some might say on this forum, to that end the end result will prove reasonably reliable.
Take any engine to a higher power/torque and feel the buzz, but the end result will end in one thing.....premature engine failure.. fact Thumbs Up
200 bhp great but for how long
LR multi million £ company.. independent 5 bob millionaires Thumbs Up
Nuff said Rolling with laughter You only have one life, live it....forget the cost.
90XS Hardtop
Post #234518 10th May 2013 10:40pm
bell-auto-services
looool
Ill make it as simple as I can of what I THINK you are hearing from how you explain things, without me sounding also like a stuck record and providing what you describe is an air movement from the turbo noise here goes nothing!
The puma 2.4 engine uses 16gs/second air to breath at idle speed, fact.
As an example figure in STANDARD format some comes from the wing vent via the turbo, some from the egr via the burnt exhaust gass. Lets say for exapmple its split 50/50, 50% from wing vent/turbo intake, 50% from burnt gass = 16gs/second.
We add a map, close the egr:
where does the 50% or 8gs/second worth of missing air now come from because we have shut the egr thats still needed to make the engine run at idle ?
would demanding double the air from the wing vent through the turbo double the intake and turbo noise at idle?
would the double air make double intake noise as the engine is switched off, and you now here the air movement correctly now the engine is not running ?
Would that be the noise you are hearing ?
Mechanical rotation cant be the noise you here, it will be an air noise from sucking or air passing over the compressor or the compressor moving the air as it spins, the baring insinde the turbo does not make a noise when the compressor is spinning within it.
Pete
Post #234520 10th May 2013 10:46pm
Happyoldgit
Lol, I hear and, despite what you might think, understand what you are saying Pete.
If the turbo bearings were on the way out might explain mechanical rather than induction noise but it isn't consistent between the two maps - given the volume of air might be the same whether it is coming either partially or wholly through the wing vent.
If, and it is if, I get time I'll make a comparison video. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #234525 10th May 2013 11:13pm
bell-auto-services
I give up Big Cry
Post #234527 10th May 2013 11:19pm
Happyoldgit
Me too. Steve.
Post #234528 10th May 2013 11:20pm
bell-auto-services
Miserableolgit wrote:
I refer to mechanical rotation type noise from the turbo itself.
It it a mechanical noise or not ?
Post #234529 10th May 2013 11:20pm
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I had a 300TDi Discovery Auto that I fitted a full size Alisport Intercooler too and a limitless "black box" to chip it, rather coarse compared to modern remaps. I used the car for several years and 40k miles after the upgrade and it never missed a beat and had zero mechanical failures. When you disconnected the black box the difference was hugely noticeable, the vehicle was just not as nice to drive due to lower torque and you found you had to rev the engine more to get the same ammount of drive ability. Darren
Post #234534 10th May 2013 11:28pm
Naks
I think a Youtube clip should be provided, so that Pete can have a listen and comment. --
Post #234587 11th May 2013 11:02am
Happyoldgit
As I said the sound is from the turbo spooling down after engine shut down. Steve.
Post #234588 11th May 2013 11:08am
bell-auto-services
then its normal as per the explantion above.
Post #234589 11th May 2013 11:23am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
my 3.2 does exactly the same you can hear the tubo on that spooling down after swich off Thumbs Up
nothing to worry about in my opinion 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #234634 11th May 2013 2:55pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Just my 2'penneth worth ............... My puma is running the IRB410 Sport map. I cant say i've noticed any difference in turbo noise/spool down to be honest .. sounds just the same as before Neutral
The IRB map doesnt actually completely shut down the EGR valve operation though - perhaps that is why Question Guns and Landrovers .... anything else is irrelevant.
Post #234743 11th May 2013 9:16pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
No spool down noise here with the original map, the original BAS remap with EGR off or the new BAS remap with EGR off, all with a Mantec plastic RAI. But I do idle for 30secs before switch off, always have done. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #234782 11th May 2013 11:43pm
I do have spool-down noise after applying the original BAS no-EGR map, and had never noticed any on the original map. It is possible that the noise from the EGR may have masked the sound, but to be honest I doubt it.
However I would expect the turbo to be spinning faster on tickover with a no-EGR map for the following reason (which I am surprised no-one has mentioned earlier in this thread).
When on tickover with the EGR open, the engine will be drawing in a certain volume of intake gasses, some of them from the air intake and some via the EGR. The engine will then be exhausting a significantly greater volume of exhaust gasses, some of which will be diverted from the exhaust manifold back to the inlet via the EGR, the remainder being passed though the turbine side of the turbocharger to exhaust to atmosphere.
If the EGR is shut with a map, even though there is no design change to the operation of the turbo at idle, assuming the same tickover speed the engine will be breathing the same volume intake gas and exhausting the same volume of exhaust gas. Now however all this intake gas will be coming via the air intake, hence the potential increase in induction noise as explained so well by Pete above, and significantly *all* the exhaust gasses (rather than just a proportion of them) will be passing through the turbine. A result of the gas laws will be that the velocity of the exhaust gas under these curcumstances will be greater than with the EGR open, hence the turbo will be spinning faster than it would be with the EGR open. Consequently if you shut down the engine the inertia of the of the rotating components will result in a longer spin down time. Inevitable. Either live with it or don't ness with the EGR! If you have changed the exhaust system (eg a de-cat or silencer removal) to reduce back pressure the effect will be exacerbated.
I suspect that the reason that some people hear it and some don't has to do with the condition of the turbo bearings. Mine (at 120k miles) makes more noise than any turbo I have heard before, but if/when it fails it is an opportunity to fit a hybrid turbo in its place!
All turbos will continue to spin for a while after engine shutdown, and the bearings are designed accordingly. Clearly it isn't a good thing to happen, and that is why it is *always* recommended to allow a turbo engine to idle for a while before shutting down (this also allows the turbo and bearings to cool). Failing to do this will do far more harm to a turbo than operating one with a no-EGR map.
Bear in mind also that in the days before EGR valves all turbos spooled down like this anyway, and they don't fit crappier bearings just because EGR valves are now mandated.
Post #235120 13th May 2013 11:25am
big steve
Extremely informative Thumbs Up 2015 2.2 tdci hardtop xs
Post #235126 13th May 2013 11:57am
Page 3 of 4 <1234>
