Home > Technical > Faulty temperature gauge and loss of power
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
In Morocco heading to Casablanca then up to France.
Engine runs fine, it's not over heating but the temp gauge shoots up to max and as it does the engine splutters and looses power.
The gauge then drops after a few seconds and normal service is resumed.
Any ideas? Just waiting to talk to Land Rover in Casablanca
Checked system with Nanocom no faults registered.
Post #234368 10th May 2013 2:02pm
dgardel
Italy
Check the relays under the (you are from UK) driver seat (the first if you haven't the ABS, the second otherwise) and the battery connections Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #234373 10th May 2013 2:30pm
Martin
Site Admin
Isn't this also related to a poor earth connection to the ECU casing?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #234374 10th May 2013 2:32pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
The ECU is losing power (I'm assuming TD5). The temperature gauge is modified by the ECU to read correctly (inverted and adjusted) so when the ECU loses power the gauge just uses the signal from the sender so it normally goes over to full deflection. Obviously an ECU with no power will also cause the engine to die.
The main causes of this are the main relay (bad connection or bad relay), battery connections, earth connections. The main relay supplies power to the ECU when the ignition is turned on so that's always the first thing to check as it may have come loose in it's base. http://www.yorkshireoffroadclub.net/
Post #234382 10th May 2013 3:06pm
deep down
Checked all the relays there were a few loose. After the 10 days through the dunes and mountains with all the vibrations and a few hard knocks I imagine I have a few loose connections.
It seems to be ok at the moment but I'll remake all connections when the vehicle gets back.
It's a Puma. One other problem I had was that after a heavy knock/ landing the hazard lights would come on and could only be reset by turning the ignition on and off twice.
Thanks for all the info
Post #234593 11th May 2013 11:29am
Laurie
It kept happening to me (TD5).
Turned out to be a partially blocked radiator.
http://www.defender2.net/forum/topic14323.html
Post #234595 11th May 2013 11:40am
