![]() | Home > Td5 > Td5 issues |
| appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630
I'm watching this as seem to suffer similar issues, sometimes a thoroughbred, sometimes a cart horse...
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
It's been very windy lately.
Have you taken wind direction into account? This is no joke, it really does make a difference. ![]() |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
I wonder if air pressure makes a difference as at altitude it makes a massive difference to performance. It may be worth Making a note of the weather conditions on the days you notice a difference or having a barometer in the car?
Altitude shouldn't make a difference to a turbo.
Seriously affects normally aspirated diesels. ![]() |
I meant the air pressure at altitude
Edit: just reread your comment and didn't realise there would be a difference with being a turbo'ed engine |
| barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1458
Humidity will make a difference, as altitude due to the denseness of the air, but the effects I would have thought would be negligible and unnoticeable on standard engine.
I would check all the turbo pipe work. Have you checked for a sticking wastegate, oil in the loom ?? |
| adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 266
no oil in the loom,
and I totally understand your point laurie and do notice wind playing a part at higher speeds, but doesnt explain it not running as smoothly. 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
| ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105
I had a similar issue and I change the radiator and hoses and now the power is back, I believe that the problem was that the radiator was clogged and the temperature rise making the engine less efficient, I measure it with my Nanocom (before it broke) and it use to go up to 105C now it hardly goes more than 85C. Augusto
Defender 110 TD5 2001 Discovery 4 TDV6 |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
Air flow meter on its way out?
On days that it doesn't drive well, try unplugging it and see if the power "reappears" |
had a new radiator and intercooler a year ago (had a bit of an oopsie with an oncoming d2)
recently had a new MAF too. 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
Since the problem occured? sometimes new MAF's can go duff. |
Yeh, its definately not MAF related 2003 Defender 90 Td5 CSW Belize Green - "Betty"
| TD5_dan Member Since: 24 Feb 2012 Location: Essex Posts: 449
Mine is very similar never that noticeable in terms of lack of speed but some days just seems to have a few more bhp than another. I actually put it down to weather and air temps/ air pressure. Mine has 46k on the clock, new injector loom, well serviced. Never actually seen what it drives like with maf disconnected. 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon 1970 Series 2A hard top 1960 Series 2 1972 Series 3 |
| Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203
Mine is the same. Safari snorkel etc.. Done all the usual suspects. Can be dangerously slow at pulling out in traffic-then goes like a flying machine????
