![]() | Home > Puma (Tdci) > battery tray |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
Just the four bolts under the vehicle. 130 crew cab
98 V8 Disco |
Perhaps take the opportunity to waxoyl etc. under the tray and under the vehicle at the same time - typical rust spots
![]() But shout it at them in German because life is also terrifying and confusing... |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
damm.....only saw the post now on the waxoyl.
I took out the plate - bent the sides down (remember the new bat is now 4cm longer but the same width and height. Worked great!!! I can recomend this battery: Varta Start-stop plus AGM 105 amph. It packs 15 amph more, fits great and 150 CCA more! Lets see how long it lasts. |
