![]() | Home > Puma (Tdci) > Low range indicator |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Never seen it. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
David128 Member Since: 31 Jan 2010 Location: Melbourne Posts: 30 ![]() ![]() ![]() |
The low range graphic exists, you can see it if you shine a bright light on the box section in the rpm dial. Also the wiring diagrams and electrical library describe the electrical circuit. It looks as though it runs direct and not through the ECU. The description in the manual confirms that there is no bulb check when starting.
Maybe a mid-life enhancement.......pending.... |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
There was a discussion on this some time ago - i would be interested to get it working - i tried...couldnt find where the break to stop it - the switch is in place and the cables seem ok - i wondered if it was just no bulb fitted - but didnt want to remove the clock Mike
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
The amount of times I've been driving down the motorway only to find I'm in low range
![]() + New Defender 110 First Edition |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Really? How on earth do you not realise ur in low when you pull off from standstill!? ![]() |
![]() ![]() From my experience of UK traffic, motorways are perfect for low range…. WRT low range light - curiosity, for the same reason as to why is the driver’s seat belt warning light not enabled although there is a circuit diagram and description in owner’s handbook. |
so it's you Derek,causing the tail back on the Stewart Highway ![]() 1968 1/32 scale Britains 109 Pick up. |
There is the wired indicator into the dashboard......
There is the connector attached (but not connected, attached on a metal clip) on the right side of the gearbox........ This spring I'll try to do somethings....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Down here it's the Stuart Highway and its about 680km to the south west of me and currently unreachable by vehicle. 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 671 ![]() ![]() ![]() |
Am I right in saying the dials are the same as the D3, I think that could be a leftover.
If i'm wrong, i'm sure someone will highlight the error of my ways. ![]() |
It looks the same but isnt and the press release ones it worked! As for why do you need it...you dont but then why do you need a winch etc...its a gap there is a light, it has a loose funtion - bingo ![]() |
