Home > Off Topic > one for the sparks
Caterham
one for the sparks
hi,
I appreciate there can be a big gap between good workmanship / good practice but I wonder if there is a 'requirement' / regulation that insists on cables being supported properly.
in that case I'm talking office environment / ceiling void. in the regs it mentions cables should be supported to prevent damage to them but thats about the lot !
so the way I see it slinging cables across suspended ceilings is ok Shocked
albeit poor practice so far as I'm concerned.
thanks.
Post #233363 7th May 2013 10:41am
MartinK
I think you are right.
all "best practice" and guideline rules do suggest that cables must be laid in trays/trunking/supports, and any data and mains cables cross at 90 degrees etc...
But I believe it's guidelines, best practices etc, and not a legal requirement...unless it's part of local authority planning regs?
I'm not an expert but I was involved in Data Centre design work a couple of years back...we always insisted on proper cable management.... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #233377 7th May 2013 11:31am
Les Brock
Re: one for the sparks
PM sent as I cant upload pdf file Sad
Its in my gallery now if your interested
Regards
Les
Post #233416 7th May 2013 2:02pm
