Home > Puma (Tdci) > TDCI fault codes and MAF/EGR dilema
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Okay so i have been having trouble with my defender since i bought it 3 months ago, its an 08 plate 90 2.4 XS SW.
So iv been putting the BAS tune box on recently to read and clear the codes that are flagging up. Most common are :
Quote:
P0110
Intake air temperature circuit
P0100
Mass or volume air flow
P0404
Exhaust gas recirculation control
P0606
engine control/powertrain module
P1103
Mass air flow sensor in range but higher than expected
So i was testing the MAF last night by unplugging it and TBH didn't notice much at all. I can definitely hear the EGR valve doing the self clean cycle after shutdown, i can hear it from the cab with the everything shut, is this normal? Also it has a JE Engineering '180'BHP remap on it and has returned around 22/23 mpg since i bought the motor. Even with the map i thought it would have been better, even if i drive like my granny it doesnt go far north.
So i have bought an EGR plate from ebay with a hole in it to try that, and am also thinking about buying a new mass air flow sensor. Does this seem a reasonable fix? Is there any way i can test the sensor using an ohmmeter? or clean it with something?
To fit the plate to the egr would it be best for me to remove the unit and use brake cleaner to scrub the internals befor the plate is fitted?
Many thanks,
William Arthur William
Post #233074 6th May 2013 8:51am
K9F
The P1103 code is what I call a 'nuisance' one and I get it periodically. After a few driving cycles that one would clear anyway along with the MIL light that accompanies it if no reoccurence arose. The remainder do seem MAF/EGR valve related and I personally think you're going down the right track.
To be sure I would drop either Lorryman or Pete at BAS a message as they are 'in the know' and would be only too willing to advise further.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #233085 6th May 2013 9:46am
william8
Thanks for the quick reply, is it worrying that I have no MIL light on the dash?
Ill have a wee fiddle and give pete a call after I've swapped out the maf . William
Post #233088 6th May 2013 10:14am
EGR 'chatter' whilst on idle is what my EGR was doing before it stopped working correctly. It was also the time it started causing problems and also affecting MAF readings too. I replace the EGR for a new one and had no trouble at all since. If you want the EGR shut by a map then IIRC then general thinking is that the EGR has to be in perfect working order first or it will still cause problems even if blanked off and not in use. (Happy to be corrected on this though) ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #233096 6th May 2013 10:54am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
The egr plates are good but the only true cure is a egr close in a remap ? Using a plate with a hole eventually the engine management light will now old is your vehicle it may need a software update also personally and this is what I did with my 2.4 I had the egr shut remap file from Pete and also blanked it right off with no holes
I have done the same on my 3.2 Thumbs Up
If you need any more info let me no
Kind regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #233098 6th May 2013 11:40am
william8
can i have your engine steve ? Laughing
Yeah i think it will be a case of going to Pete.
However as a short term solution (im a student) can i remove the EGR valve and clean it ? William
Post #233103 6th May 2013 1:04pm
Good luck is all I will say. Neutral I'm damned if I'd go through the pain of removing it just to clean it. I removed mine and replaced. On top of it being a b****er to get out and re-fit you'd have to take it apart partially too all the while you cannot drive it at all until it's completely removed and re-fitted. ____\We|Will|Win/___
Post #233111 6th May 2013 2:29pm
big steve
Hmm lol depends how much money you have for my engine lol
I supply Petes stuff so could do it although you need a complete new remap I'm afraid but if I was to do it I can update the software at the same time at no extra cost Thumbs Up
Steve 2015 2.2 tdci hardtop xs
Post #233113 6th May 2013 2:49pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
It is a pain in the arse, but not too bad. In total it took about 2 hours to remove disassemble clean and put back on. Well worth having a clean out though, my EGR now closes properly.
Regards,
Mark
Post #233130 6th May 2013 4:45pm
Mark - Mine was tuck closed IIRC rather than open. What did you use to clean with? I assume it was coked up? ____\We|Will|Win/___
Post #233135 6th May 2013 5:01pm
pope10001
Mine had a slight crack keeping it slightly open with the build up of carbon.
I used carb cleaner and the wife's toothbrush, she wasn't impressed... It came up really clean though.
Regards,
Mark
Post #233137 6th May 2013 5:07pm
Thumbs Up ____\We|Will|Win/___
Post #233153 6th May 2013 5:49pm
william8
Sounds good mark so did yours go through the shut down open and close cycle? But you had fault codes for it?
Just trying to see if we have the same symptoms. Sounds like a good wee job for after the exams Very Happy William
Post #233184 6th May 2013 6:50pm
K9F
Steve,
I've been running with a remap and EGR blank with a hole since May 2010 when Robofarmer first knocked them out with no issues whatsoever.
http://www.defender2.net/forum/topic3115.h...egr+blanks
Post #233188 6th May 2013 7:04pm
big steve
K9f have you go egr shut in your map though ?
As if you run with just a hole in a plate it will throw the light up as I tested it on the plates starting with the smallest
Post #233190 6th May 2013 7:07pm
