Home > Technical > Mot....Rolling road brake test?
Clemmo
Was just wonderin Question
My Puma is due it's first MOT.
Is it ok for the garage to put front and rear axles separately on a single axle rolling road to do a brake test?
Or not?
(My local garage only has this facility )
Cheers Thumbs Up
Clemmo
Post #232653 4th May 2013 1:37pm
mk1collector
They should be able to do an on road brake test
Post #232657 4th May 2013 2:03pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
They will use a decelerometer and carry out the brake test via a short drive.
Make sure your chosen test centre are familier with transmission handbrakes [as fitted to Defenders] .. these cant be tested in motion [rollers or road test!] Guns and Landrovers .... anything else is irrelevant.
Post #232668 4th May 2013 3:29pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Just had my Puma mot`d last Saturday(Pass!) and test station used a decelerometer on a test drive to check brakes. Tested handbrake held on a hill and that was it. Smile
Post #232670 4th May 2013 3:38pm
Clemmo
I know how they can do it...and should do it.
When I was up there last week they had a 300 Tdi on the rolling road.
Just wondered how that was possible?
( transfer box in neutral?.)
Or...are they damaging the car?
Thumbs Up
Clemmo
Post #232678 4th May 2013 5:03pm
Potentially, yes. Darren
Post #232687 4th May 2013 6:33pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Because of the cdl defenders can be rolling roaded. Mine has been 3 times for mot plus once to diagnose a brake fault. Rhubarb and custard let fly with their secret weapon.
Post #232690 4th May 2013 6:59pm
If you lock the cdl on a single axle rolling road, it will drive off with the other axle. Darren
Post #232691 4th May 2013 7:08pm
Glynparry25
It is fine to put the Defender onto the rolling brake tester...... and in all honesty it should be as they are much more accurate.
Land Rover manuals state that you can run on a rolling road up to 5mph- no need to put the diff into neutral etc- it's job is to allow the rear axle to move at a different speed to the front. As long as you don't go in excess of 5ish mph you will not do any damage at all.
Decelerometer is a terrible form of test and should only be used if a RBT is unavailable- this should also be backed up with proof otherwise the test can be classified as void as it can be easily fooled.
Glyn Dog Sheep
Post #232692 4th May 2013 7:28pm
GUM97
Or a 2 axle rolling road. Came across one of those only a few weeks ago for the first time. Clever bit of kit! Thumbs Up An engine to TDi for!
Post #232857 5th May 2013 3:54pm
