![]() | Home > Technical > Power Steering weak (non Puma) |
| d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044
Hi
Need a bit of advice please - power steering has been gently seeping oil for the last 5 or 6 years and a top has kept it in good order so no problem with it. This time I went to top up and having left it a while it was quite low on oil and steering very heavy. After top up, its a lot better but still seems 'heavy' on nearly full lock (both ways). So the question is really - does the power steering have a bleed system like brakes/clutch in case I have an airlock somewhere from letting the fluid go a bit low. If not can it be made less heavy or am I looking at a replacement pump at last? ( I don't mind it being heavy, its just not consistent across the steering travel , so feels a bit unpredictable!) Cheers DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
| Stoney Member Since: 28 Sep 2012 Location: Hampshire Posts: 87
Mine is 300tdi so might be different but there is a bleed nipple right on top of the steering box
Thanks for that , I'll have a look see tomorrow, I'd imagine they have been the same since day one Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
