Home > Puma (Tdci) > are they any better now
Daniel TD5
United Kingdom 1986 Defender 90 Other ST Nato Green
ok you lot the men in the know
after having one of the very first 07 TDCI double cabs and it falling apart over two years.
all the normal faults i left landrover ownership
i have had a toyota hilux auto for the last three years its due to be changed in a few months
i could have a 110 xs utilly is it worth going back
are they now better than the 07 model i now do 60k in three years so a lot more miles
will i end up with big problems
thanks for your help
regards
Daniel
Post #231969 1st May 2013 11:28am
Green Machine
The simple answer is no. Not significantly.
What specific problems are you referring to? Certainly in terms of general fit and finish there is no significant improvement since 2007. Don't know if you are aware that Defenders are now using a new 2.2 4 cylinder diesel, rather than the 2.4 that was fitted to your 2007 model. But again, most of the reports from owners of the new 2.2 on here don't really demonstrate any significant improvement. Maybe a bit quieter, and a bit of a question mark over the Diesel Particulate Filter (DPF) technology of the new ones, although no one here has had any specific problems with that as far as I'm aware. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #231970 1st May 2013 11:33am
K9F
Drop a 'pm' to 'Noworries' he can knock the 60k into a cocked hat the mileage he does. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #231971 1st May 2013 11:35am
Daniel TD5
my 07
went through the following
5 clutches fell apart
1 gearbox
fuel system problems
erg valves
limp mode on most journeys erg or fuel system faults
full respray
rust
abs faults
loads of engine oil leaks
all the normal stuff water in fuel from breather pipe and so on
Post #231980 1st May 2013 12:23pm
ibexman
ERR no Whistle
Post #231983 1st May 2013 12:37pm
Daniel TD5
ibexman wrote:
ERR no Whistle
but you did runner from your 07 before me you had a nice green td5 last time i met you
how are you
Post #231985 1st May 2013 12:43pm
Mine a 57 plate. Only had a diff pinion oil seal go. (Maybe my fault recovery related) and EGR valve change which had exceeded it's working lifetime anyway...
Other than that only normal maintenance items. _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #231986 1st May 2013 12:46pm
Well my 07 DC has now done 120,000 miles with only the following:-
1 clutch change
1 front diff failure
1 set rear halfshafts/drive flanges
Whilst that is appreciably more parts than my TD5 Disco neede in the same mileage, I don't think it is cause for complaint.
Post #231990 1st May 2013 12:49pm
barbel jim
Daniel TD5 wrote:
my 07
1 gearbox
erg valves
full respray
rust
abs faults
The first 2.4's had a few 'lemons'. The 2.2 is a totally different set up. it is an older engine than the 2.4, but has alot of people excited by it. The usual Defender traits are still just as bad, Rust etc. Think it would be worth going and having a look and test drive. Thumbs Up
Post #231993 1st May 2013 12:54pm
ibexman
Daniel TD5 wrote:
ibexman wrote:
ERR no Whistle
how are you
Yes Dan still got it Thumbs Up
Post #232000 1st May 2013 1:43pm
JSG
My 2011 seems very similar to my old 2007 model - no problems with either of them worth worrying about. Thumbs Up John
2011 Tdci 110 CSW XS
Post #232019 1st May 2013 3:24pm
Happyoldgit
Not sure I'm very excited about it Shocked
To answer the OP then I would say no, I cannot see any vast improvement between the current offering and the 2007 version. They still leak, require basic rustproofing from the word go, have paintwork that marks at the merest touch of a twig, have powder coating that wants to flake off various bits with regular monotony but also have the added bonus that the ecu wants to control the revs despite driver input and are now burdened with a DPF. Steve.
http://forums.lr4x4.com
Post #232030 1st May 2013 3:55pm
keith
FFFFFFFF @#€? Ok so 25 yrs and 14 LRs later and a new 2.2 2012 110 XS . I recon I'm pretty qualified to answer that question . Failed clutch , failed turbo hose , failed track rod ends x2 , failed swivel housing oil seals , supplied with no under felt or carpet , failed headlight plug , thinner chassis , panels and allround cheeper poor quality parts . Bumper is in the bin rusted away . 2.2 revving problems to tick the boxes of the EU emitions , paint quality is shocking . Just because it's got 6 gears and a cumfier seat doesn't make it a different car . A gloryfied series 3 if you ask me . If your into Landrovers then you know what your gettin - the worlds most iconic car that everyone wants , with 65yrs of inherent inbuilt problems that will never go away . Gees they've only just gave us a heater with a half deesent blower . I still love it though .
Post #232047 1st May 2013 5:25pm
Dieselhead
We have an early 110 2007 at work which we have had from new.
Just given it its 24,000 service.
Only problem we have had was it got stuck in 1st gear & we removed the gearbox to get it checked out by a gearbox company. I put a clutch in it as the springs were very loose Shocked
My 08 110 has just hit 58K with no probs apart from a few leaks one of which I an still chasing Laughing Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #232111 1st May 2013 9:35pm
Daniel TD5
Well I have booked a test drive in the morning
Looking at a black 110 usw xs spec
Will let you know the out come
Post #236418 17th May 2013 7:54pm
