Home > Maintenance & Modifications > Do 255/85/16 fit a Defender 90 without a lift??
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
As above, thinking of new wheels/tyres and I've seen some posts suggesting 255's rather than the normal 235/85 or 265/75 options.
Has anybody done this to a std height 90 without rubbing problems?
Post #230954 27th Apr 2013 4:19pm
leeds
We are running our black 110 on BFG 255/85/16 M/T on Zu rims on standard suspension with no problem
Brendan
Post #230957 27th Apr 2013 4:40pm
Lambley
Thanks Brendon, I've seen some on a 110, but are 110's slightly higher or have stiffer springs for the extra weight?
Post #230960 27th Apr 2013 4:43pm
ibexman
YES they do you may have to adjust steering stops Thumbs Up
Post #230967 27th Apr 2013 5:23pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I have BFG KM2 MT 255/86 x 16 on my 90. It isn't lifted or modified in any way in the suspension dept, and all is well.
Wheels are standard Freestyle alloys as fitted to 2001 County spec Defenders.
Simon
Post #230970 27th Apr 2013 5:44pm
Lambley
Cheers Couplands, have you had any rubbing under the arches? Did you notice a difference in gearing at all?
Post #230974 27th Apr 2013 5:53pm
TJ101
Never had a problem with 255/85/16 BFG MT or either a 90 or 110,, bar a faint possabilty of the rear rubbing the wheel box, on full articulation California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #231021 27th Apr 2013 8:38pm
Lambley
Cheers TJ, I don't think I'd ever get to full articulation to be honest.
Next question, does it help with the gearing, I've calculated they are about 4% higher geared, I'll probably be doing a transfer box ratio change through Ashcroft, maybe going to 255's will be a half way house?
Post #231024 27th Apr 2013 8:43pm
TJ101
Would be about right,, The speedo will read just under GPS speed, at 60/65mph California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #231025 27th Apr 2013 8:48pm
couplands
If I recall, they are about 1" larger in diameter than the standard 235 size, and roughly the same as the optional 265/75 size, well within the 10% range of error for the speedo.*
Given the small size difference, there is no where that the tyres rub and I do plenty of full articulation driving.
Simon
* the actual diameter varies based on the brand of tyre. You can check the BFG diameters on their website, not sure about other brands, but I guess they do.
Post #231029 27th Apr 2013 8:55pm
TJ101
255's are 4.22% taller than 235 or 34mm from memory
The tyre can rub on full articulation,,but only in the rear arch when running Mack5's or Boosts
On my 4th set of BFG MT's, from 200Tdi, to Puma, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #231031 27th Apr 2013 9:10pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
per TJ101, they also rub at the rear on full articulation when tyres on modulars with a 90 on a Terrafirma 40mm lift.
Post #231041 27th Apr 2013 9:57pm
here's a link to a tyre size calculator
http://www.tyresave.co.uk/tyresize.html
it looks like 265/75/16s are within 2mm (or -0.25%) of the standard 235/85/16
so 255/85/16's are 4% or 34mm larger
Post #231078 28th Apr 2013 8:15am
Jimmiboy
2002 Defender 110 Td5 XS DCPU Bonatti Grey
Simon
Hi There, would you mind posting a pic?
Jim
Post #231102 28th Apr 2013 9:59am
Lambley
Simon
Jim
Yes, that would be helpful
Post #231113 28th Apr 2013 10:20am
