![]() | Home > Technical > Spotlight bulbs |
| NickEJ Member Since: 24 Nov 2012 Location: Ljubljana Posts: 152
Morning all
Does anyone know the part number of or where I can buy a replacement for the spotlight bulbs fitted to a soft A-bar on a 2004 Td5 XS. I've taken the bulb out and on the base plate it looks as though it says 28w. Is that right? Had a quick search on t'internet but with no joy. Chiz Nick |
That's what I thought. 28w spotlights would seem to be a contradiction in terms. Hoping that the Defender2 knowledge base will come good!
| TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333
If it helps the Rally1000 lights on the TR vehicles (2001) use 55W H2 bulbs.
They look like this: ![]() |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Put up a pic of the lights then we might be able to tell you which type of bulb you need
Mk1Collector wins!
Just had another look whilst retracting bulb and, although barely legible, i can just make out that the holder is an Osram 55w fitting which does make sense. Having checked on-line it's also clearly an H3 bulb. Well done chaps, good job. Nick |
