Home > Puma (Tdci) > has anyone had this leak ?
rossy
Well I thought I had fixed my leaks (wet footwells) by sealing the window frame/bulkhead gap but I am now beginning to realise that with these vehicles as soon as you've fixed one problem there's a queue of others waiting to pop up.
Just above the rusty bit in the pic there's the bulkhead insulation and if you put your hand behind it its wet although just in that bit ( not left or right of it thankfully)
Has anyone had something similar and could give me a few pointers as to where to check ? Thanks
Post #229145 20th Apr 2013 5:42pm
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
Got this same leak ... like you can't figure out where it comes from ...
The bulkhead/window frame seal here in Malaysia is done with silicones at the factory.
I also sealed the rubber around the windshield. That has stopped it for the normal rains, but still returns when we have those tropical downpours here.
As far as I can figure it out the water seeps through via the rubber around the windshield.
Stephan
Post #229234 21st Apr 2013 4:12am
Dieselhead
I have this also.
I need the winscreen replaced so have purchased a new seal ready
Will ask the guy to pump plenty of sealent in also to see what happens Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #229247 21st Apr 2013 8:09am
nidge n
I had this one and was easily resolved. It was the seal around the false hinges for air vents (puma). Resealed and no problems to date. I hope that helps
Post #229416 21st Apr 2013 6:01pm
Grockle
windscreen frame to bulkhead seal 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #230465 25th Apr 2013 4:33pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Window blocks? The gasket is terrible.
Post #230477 25th Apr 2013 5:41pm
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
Bulkhead to screen blocks is a good place to start - mine need doing, the blots/nuts are rusting on the inside 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #230746 26th Apr 2013 4:43pm
rossy
thanks for the advice everyone Thumbs Up
Last year I sealed the notorious 'gap' and windscreen rubber and put a thin bead of sealant around the windscreen hinges but it was a quick rough job (I got more on my hands). I need to do it again properly this time !
Good to know thats where its definately coming from
Post #230777 26th Apr 2013 6:52pm
