Home > Wheels & Tyres > Balancing 18" Twisted alloys
mcma1
Has anyone had any issues balancing the 18" twisted alloys? I have them currently with 285 65 18 BFG AT with already a load of weights added, get a little shuddering around 50.... has anyone had to add some weights on the outside?
Post #230701 26th Apr 2013 2:33pm
griffman
United Kingdom 1984 Defender 90 V8 Petrol CSW Auto Keswick Green
don't fret about it - they are virtually impossible to balance perfectly.
Post #230704 26th Apr 2013 2:36pm
mcma1
I know its nothing major, just when i had the micky t MT's on they were spot on, although I had to have some weight on the outside of the rim
Post #230707 26th Apr 2013 2:39pm
familymad
It's not a UJ on its way out? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #230717 26th Apr 2013 3:04pm
Where are you based ?
Post #230727 26th Apr 2013 3:36pm
mcma1
Hillsborough in NI Sad
Post #230737 26th Apr 2013 4:13pm
Sorry then if you were here we could show you Thumbs Up
Post #230744 26th Apr 2013 4:39pm
mcma1
Why not tell me??? Confused
Post #230808 26th Apr 2013 9:17pm
bcarlin
Oh we'll there not worth keeping if they are out of balance, I'll buy them off you then Laughing
Post #230817 26th Apr 2013 9:44pm
Nothing to tell , just show you balance them to below 5g find out if the rim and tyre has high spots etcetcetc
Once you know they are balanced if its still there then you can move on
Post #230824 26th Apr 2013 10:13pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
My twisted alloys shake a bit at around 50 but if its 60+ or less than 50 its alright. Is this roughly the same as yours ? William
Post #230854 27th Apr 2013 7:48am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
A few years ago I bought a full set of Tyres for a 300 Tdi 90, it had standard steel wheels, from a large tyre company. They could not balance them up even with 100g weights all over the rims so I just put up with it.
A couple on months later I needed a set of Tyres for the caravan and went to an independent dealer who was cheaper then anyone else, I watched him balance the wheels and it was very enlightening, he first spun up the rim and marked the heavy point then put on the tyre and spun it up marking the heavy spot, deflated the tyre and shuffled it round re inflated the tyre and stuck a 5g weight on.
While he was doing the other 4 I started talking to him and he told me that not only can the rims be out of balance but so can the tyres and by doing it the way he does it you can almost get rid of the out of balance. I told him about the 90 and the problems the other company had had, forty minutes later I had perfectly balance wheels and tyres on the 90 and a sack load of weights to take home.
Post #230896 27th Apr 2013 11:24am
K9F
^^^^Spot on! Thumbs Up
Invariably it's down to the dedication and determination of the tyre fitter and of course how busy/how much time they have but if there's a lot of weights needed by rotating the tyre on the rim the weights can be reduced by finding the optimum position for the tyre. I had the spare done but when the rest were fitted they were too busy and just stuck the tyres and weights on without rotating. I wanted some feedback on balancing beads as they may negate the requirement for weights perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #230899 27th Apr 2013 11:32am
mcma1
Yes the same,,
Had a front on a balancing machine today, currently has 125g on the outside behind the spokes, and 70 on the inside. Asked for another 175g on the outside and 60 on the inside! I will just stay below 50 for now...
Post #230956 27th Apr 2013 4:37pm
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
Ever thought of using Dyna Beads?
I use them on my motorcycle, no more unsightly weights stuck to the wheels, more even tire wear and more importantly nicely balanced wheels.
http://www.dynabeads.co.uk
Post #231066 28th Apr 2013 4:02am
