![]() | Home > Td5 > Opinions please... |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
no i wouldnt change it.
plenty of non std, pattern parts out there that are more than capable of doing the job. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
Even if you dont change it and it fails it wont cut off the engine it will just keep running "normally" but probably will affect the MPG.
If it fails and you suspect it makes your engine cough the disconnect it and go merrily. Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Thanks chaps.
I maybe have an irrational fear of all things non OEM. |
Postmanpat Member Since: 01 Aug 2012 Location: Co.Limerick Posts: 50 ![]() ![]() ![]() |
wouldn't change it either , wait until it fails . If you find your power to get poor , disconnect it . If its makes a hugh diff its mostly a sign that the one you have is faulty . But you can leave it disconnected until home or you get a replacement but it will ( not probably ) effect the mpg . Postmanpat |
