![]() | Home > Stolen > Parts Removed ... Nr Doncaster |
| Tony Member Since: 13 Mar 2012 Location: West Yorkshire Posts: 72
Yep, you're probably right, I guess I was a bit too quick to assume it'd been stolen I made a temporary one from black styrene sheet whilst waiting for the new one to arrive, and held it in place using the screws that hold the inner plastic moulding, maybe LR should do the same! I've kept the temporary one anyway .......... just in case! Cheers! |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Tony - I started to think the opposite way after hearing of yours - wondered if it fell off after someone had tried to nick it! Did yours have all the plastic pegs snapped off and left in the wing like mine? if not then maybe yours was carefully removed and stolen? |
| farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299
the bottom of my side vent is no longer flush with the bodywork - assumed it was LR's new build quality regime
Hi Supacat,
Yes, mine was exactly the same, all the pegs broken off flush. I thought someone had tried to prise it off and broken the pegs in the process, but then when I bought the new one and realised how loose the pegs are I started to think otherwise. It's a pretty poor idea for something which is mounted vertically, as you said a couple of self tappers would do the trick. If it happens again I'll put the home made one back on and leave it on. Cheers! |
| steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076
Hi guys
Mine fell off while cleaning by hand last week. I noticed it wasn't held on by anything more than luck dealer replaced it no probs. |
| Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941
Mine fell off at te car wash and I made the washers pay for the LRS corsetti one
http://www.lrsshop.co.uk/content/cor4-air-intake-grill The screws are top notch but I didn't want to riv nut the area so just pop riveted it. So easy even for an office boy like myself. Can post pictures if requested Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
