![]() | Home > Technical > Clutch release bearing genuine or not? |
Genuine. For that money it's not worth saving a few quid only to have to take the gearbox out again if it fails. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
+1 ^^^
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
Isn't there a release bearing in the clutch kit? I've fitted about 5 valeo clutches to td5's and its always had a release bearing in the box!
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Definitely Genuine. I recently had a gearbox change, a R380 into a 200Tdi which required a new release bearing. A non genuine (not sure which make) one was installed which caused the clutch to slip but only in 5th gear, on removal of the gearbox the release bearing was knackered. The metal bearing was just falling off of the plastic sleeve which it should have been a tight press fit on. Once replaced with a Genuine part i have had no problems at all.
HTH Regards, Mark |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 ![]() ![]() ![]() |
Ok thanks to all of you
![]() Genuine part ordered. Just got to get it all fitted next ![]() |
