Home > Technical > clutch / box
Page 1 of 5 12345>
Caterham
clutch / box
Big Cry
can't believe I'm here asking this but......
for those at can recall (I've tried to forgot) I've had the odd issue along the way.
any how I'm 98% convinced (or was) that things are /were sorted until just recently were something seems to be getting worse (certainly no better).
pulling away from stationary and sometimes I get a kangaroo effect or the bit point on the clutch seems very short (kind of on / off).
I've also noticed while driving along at speed that the odd gear change can be very sharp (thought it was myself to start with being lazy and not depressing the clutch enough but now think it the car not me) Big Cry
any thoughts or tests I can do to establish where the problem lies?
Thud
Post #229868 23rd Apr 2013 12:22pm
Happyoldgit
Get shot and buy a Eurobox, it's the only way you are going to get a good nights sleep.
Seriously, if you have not already done so find someone local to you with a similar age Defender, have a go in theirs and get them to drive yours. An experienced Defender owner will soon be able to tell you if there is anything out of the ordinary with yours. Steve.
http://forums.lr4x4.com
Post #229879 23rd Apr 2013 1:28pm
Caterham
I'd be lieing if I hadn't thought about getting a eurobox.....
the def is now running pretty well engine wise which after more than 2 years of moaning is a monumental achievement (thats to everyone for their suggestions etc along the way and IRB for the injector learn.....and myself for cleaning the MAP sensor Very Happy )
now I just concerned that the clutch is on its way out ..........perhaps I should just check the clutch fluid come to think of it.
I know serveral people have complained about the engine revs picking up to 2k rpm on gear changes, I had this happen just once and it was recently...........and the fun begins - what could it be?
Post #229887 23rd Apr 2013 1:53pm
Happyoldgit
The 2k pickup is a feature of the 2.2's.
Checking the clutch fluid is easy and no harm in keeping a regular check, same applies to the other fluid levels.
If it is still under warranty just drive it ....but that has been said before Wink Steve.
Post #229890 23rd Apr 2013 1:58pm
Caterham
I beieve the engine revs / clutch thing is also on the 2.4's.
I've tried disconnecting the electrical connection to the clutch master cyliner and ......... the effects are quite amazing Shocked
I am 'just driving it' as previously advised Cool but it would be nice to know whats going to fail and be prepared for it than have an unpleasant suprise (like when we head off to Italy later in the year).
....hmm. I note a new def owner has moved in not too far from home. I might have to go knock on their door and see if they can give their opinion Whistle
Post #229894 23rd Apr 2013 2:05pm
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Knock knock. "Hello I am Mr Caterham, will you lend me your Defender so I can have a drive in it please, I will bring it back, honestly" Whistle
C 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #229907 23rd Apr 2013 2:54pm
Caterham
Rolling with laughter
yes I can see that might not work.
Post #229911 23rd Apr 2013 3:05pm
If "the engine revs / clutch thing" happens on the 2.4 it is an indication of a malfunctioning clutch switch. Test by disconnecting the switch (as you have done), but the sound of it your switch has packed up.
A clunky/notchy and generally unpleasant gearchange "experience" (sorry, new-wave Landrover speak!) can be caused by many things on a Puma including clutch problems, but more commonly in my experience is down to backlash in the drive train. Any wear anywhere will manifest itself as clunks and jars/snatches when changing gear. It is more a feature that you have to live with by altering your driving style to accomodate than something you can fix.
Post #229945 23rd Apr 2013 5:33pm
Caterham
thanks black wolf.
I'll have to get round to testing the clutch switch again - it may perhaps be on its way out ??
regards the gear change - I dont think its back lash / transmission as such but more something seems to have gone wrong recently?
after replacement clutch, input shaft and gearbox recently gear changes were great but something seems to have changed / on its way out Big Cry
now where's that eurobox
Post #230059 23rd Apr 2013 11:22pm
Caterham
I sure the gear change etc is getting worse.
had a look underneath and there's oil again Big Cry
to be fair there is only a very small amount on the transfer box so I'm hoping it nothing to worry about ( Shocked sleepless nights) but it does make me wonder - coincidence and all that ?
remind me the transfer box is the one thats a pig to fill right?
clutch.....
I'm sure this is gonna be a daft question but....how do you know when there's enough fluid / its adjusted correctly?
thanks.
one last thing - and I'm sure its related. 55mph (from memory thats 1750 rpm in 6th). on along the motorway and I can feel vibes in my foot on light throttle - off the gas a fraction and it goes. back on the gas very lightly and it goes (or was it the other way round...? can't remember but it don't seem right) - I'll have to go check Big Cry
Post #230790 26th Apr 2013 7:57pm
uncas
Dare I suggest? Chuck the stick shift in the scrap bin and fit an auto.
Checking clutch fluid is easy peasy lift bonnet (no not that one) unscrew top of fluid reservoir making sure that you get the one for the clutch and not the one thats bolted onto an object that looks like a miniature dustbin lid don't over fill cos it makes a mess.
Uncas
Post #230865 27th Apr 2013 8:37am
Caterham
Someone suggested the clutch springs can sometimes get stuck....assuming this is possible I guess some lubrication would help?
Is it possible to spray wd40 or similar into the bell housing and if it's possible would it trash the friction plate permanently?
Post #407735 15th Mar 2015 1:21pm
shaggydog
DO NOT DO THAT!!
Most likely effect it will have is lubricate the clutch surfaces and then you wont be going anywhere fast and it will most likely wreck your flywheel or clutch or both. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #407739 15th Mar 2015 1:35pm
Caterham
That's kinda what I thought Thumbs Up
So if it is sticking only option is to do a swap out. Crying or Very sad
Post #407767 15th Mar 2015 3:43pm
mk1collector
I thought everything was sorted with the new output flange?
Post #407769 15th Mar 2015 3:45pm
Page 1 of 5 12345>
