Home > Maintenance & Modifications > Bumper Paint
Stoo
2005 Defender 90 Td5 XS CSW Bonatti Grey
Bumper Paint
Hi,
I'm after after a bit of advice for painting my ARB bumper.
I had it shot-blasted to remove all the old powder-coating as it was all chipped and rusted underneath, and being left with a nice dimpled finish I simply painted over with normal satin black spray paint.
This was fine until the winter; and unfortunately with all the snow and salt the paint really has not faired well.
Anyone had any good experiences with particular paint for this? Ideally that will leave a nice and durable finish and is fairly easy to apply - i.e. not like the awful new Hammerite.
Stoo
Thumbs Up Thumbs Up
Post #229622 22nd Apr 2013 1:58pm
K9F
Get it stripped, dipped and repowdercoated. Less toil and probably cheaper than buying the materials! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #229625 22nd Apr 2013 2:08pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Have a look at POR 15
http://www.frost.co.uk/automotive-paint/por15-paints.html Original Member Pie n Pea Club.
110 HCPU Tipper
Post #229626 22nd Apr 2013 2:08pm
MartinK
Thumbs Up +1 for POR-15
Or follow K9F's advice... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #229630 22nd Apr 2013 2:34pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Smoothrite?
Post #229647 22nd Apr 2013 4:01pm
Killer90
Site Sponsor
sand blasted, galvinised then re powder coated Wink CSK Automotive
www.cskautomotive.co.uk
Post #229671 22nd Apr 2013 5:47pm
keith
I just made myself a 10mm 4 inch square bumper on extended brackets which take it well away from the bodywork . 100% galvanise but it's a NO on the powder coating as stone chips and weather just make it peal and bubble away and you would only be doing it again soon enough . After galvanising I etch primed and gave 3 coats of black smooth hammerite , when dry I then sprayed with smooth hammerite spray matt finish , done . You still get the stone chips but a touch up matt brush dissapears those . I'm not a fan of the powder coating sorry .
Post #229744 22nd Apr 2013 8:39pm
WarPig
Ive often thought about etch priming & painting my galvanised crossmember, sliders & bumper in black. But at the same time I dont want to spoil it incase I do it wrong!!
Post #229766 22nd Apr 2013 10:14pm
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
sand blasted, galvanised, etch primer and then about four coats of Plasticote looks brill, had no issues this winter, had Mr BMW driver catch the side of the bumper the weekend trying to park, ripped his rear bumper off at the corner, and only scuffed the paint a little on mine, was dreading looking but was amazed, a little t-cut has removed some of the scratch marks
Post #229786 23rd Apr 2013 6:18am
keith
WarPig wrote:
Ive often thought about etch priming & painting my galvanised crossmember, sliders & bumper. But at the same time I dont want to spoil it incase I do it wrong!!
Nothing to go wrong mate I my galvanised tree sliders also had the same treatment with spray silver hammered hammerite rather than powder coating . Make sure your bumper is satin or Matt , gloss is to shiny .
Post #229933 23rd Apr 2013 3:29pm
WarPig
I guess the essential part is the etch priming? Did you do this with aerosol?
Post #229964 23rd Apr 2013 6:37pm
keith
No spray , it's a blue liquid acid . Brush it on and your galvanised metal will turn black . Give it a good wash then apply your paint . Your local steel works or hardware should give you a cup full .
Post #229969 23rd Apr 2013 6:43pm
WarPig
Thanks Keith Thumbs Up
Post #229978 23rd Apr 2013 7:07pm
