![]() | Home > Tdi > On going fuel sender problem HELP! |
natyeo Member Since: 27 Jan 2013 Location: Bentham Posts: 138 ![]() ![]() ![]() |
Sender part number STC1138
Fuel gauge RTC3107 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb 2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Friend of mine had same problem with his D2! Fuel gauge all over the place. He got an oem one fitted by the garage at around twice the cost. It's all good now.
I'd try duckworths or JL services at willenhall they will sort you out I Use JL for most of my stuff. |
Finally got round to double checking every thing again bearmach sender , no different, and after another two fuel gauges, the second one was the fix.
Well all I will say is just keep trying and you'll get there! 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb 2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
