![]() | Home > Maintenance & Modifications > Recommended Garage for Mods? |
Welcome to the site! ![]() When you say 'making' do you mean manufacturing or just simply fitting? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Justinted Member Since: 19 Apr 2013 Location: Lancashire Posts: 15 ![]() ![]() ![]() |
Hi K9F
Sorry for the confusion...supply and fitting...not the actual manufacture of anything! Cheers jt |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
I'd recommend Killer 90 CSK Land Rovers. But maybe too far away from you in Herts.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Thanks for the reply Steve...but yes, just a bit too far...
Cheers jt |
No problem.
Depending on what type of roof rack you want (eg Patriot, Hannibal etc) I'd look for the nearest agent and have a word with them. alternatively get one shipped and fit it yourself as they aren't that hard to do.
Chequer plate varies in quality quite a bit and I'd recommend getting some that is shaped properly and comes with the gasket to fit between it and the body, otherwise you get all sorts of crap behind it. I tend to limit CP to wing top protectors and have fitted genuine parts stuff to both my Pumas - excellent quality. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
x2 on genuine chequer plate - lovely quality. Don't scrimp... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Trekoverland in North Yorks
![]() 110 HCPU Tipper |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1388 ![]() ![]() ![]() |
can someone EXPLAIN what they mean by RADIUS...!!!!!
Have you got some CSK chequer plate or a CSK roof rack fitted then? John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
It may be a bit far from you, but Bell Automotive are in Quensferry.
http://www.bellautomotive4x4.co.uk/ An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
@ John- Steve has some of my Chequer plate, its made by the same company which make the genuine Chequer but at under 4 times what they charge
Cool - I'll bear that in mind, sounds a good price for genuine stuff.
Do you do the sill covers in black? Do they come with gaskets? Cheers, ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
