leejunfan
ESR254 - Rear Tailpipe and Silencer - 90 200TDI (1990-1993) | |
Took the Defender for MOT on Saturday and it passed with an advisory on the rear tailpipe as it was pitted and as the wife is away for the weekend thought i might as well use the time productively without getting moaned at.
So i thought i would change the rear silencer out with this
http://www.paddockspares.com/esr254-rear-t...-1993.html
I know it will probably need new nuts and Paddocks say that the central pipe it connects to has the bolts built in, does anyone know if that is correct?
But i am not sure if there are any gaskets in between if so anyone know what the part number is or is it just a case of using the tube stuff.
Thanks in advance!
8th Apr 2013 5:29pm |
Rob
I've never used any exhaust paste on any of new exhausts I've fitted. There are no gaskets to fit. I've not put a new exhaust on my current 90.....(its a 200 tdi) I believe the bolts are built in, but check to make sure will ya? nothing worse than having a few bolts short
19th Apr 2013 5:33pm |
