![]() | Home > Puma (Tdci) > Step to step clutch exchange |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 ![]() ![]() ![]() |
Is there anywhere on the net which tells/shows you how to take box out etc? 90 Puma HT
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2679 ![]() ![]() ![]() |
Not seen one for PUMA yet - this one's on landyzone
http://www.landyzone.co.uk/lz/f7/defender-...36171.html If you need a workshop manual, as MK says, the manuals are out there (or you can PM me) for download. If you tackle the job, you could do the report, and get it "stickied" for all of us ![]() |
http://landrover.livedrive.com/ ![]() ![]() IID Pro MV License |
Cheers, yep I had found it but its a bit hard to look at on
sidler Member Since: 18 Apr 2013 Location: Netherlands Posts: 12 ![]() ![]() ![]() |
Hi all,
I am planning to replace my MY07's rattling clutch (@60.000 km ![]() ![]() I was wondering why the guy in the landyzone-manual had to drain his coolant etc. Nothing about that in the workshop manual. Is this engine-related? Does anyone know? The procedure in the workshop manual looks much easier. I thnk I'll buy an AP driveline Clutch replacement kit at Paddock's. Is this one ok? Besides that: does anyone know where to get a proper size center-pin to align the clutch plate or which diameter this is? My SIII did well with a broomstick but I'm not sure if this one will... Thanks, Paul |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
I think that the reason is that as the back of the engine drops, the radiator hose can pull the stub off the radiator unless disconnected. So drain a little coolant and remove the hose. |
