Home > Puma (Tdci) > High Revs for ~ 2 secs+ when changing gear foot off throttle
Page 3 of 4 <1234>
Ken Graham
United Kingdom 2013 Defender 90 Puma 2.2 HT Java Black
? John , how old is your Norton , mine is 74 850 mk2a
Post #227039 14th Apr 2013 12:57am
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Hi Ken,
It's a 1964 Atlas 750cc Very Happy
Had it 38 years! that makes me feel old, Used to know the guy who bought it new but he's now racing with the gods in the sky.
Cheers, John. 2.2 90 XS
88" Series One
Old Norton Smile
Modern Honda and Harley
Post #227633 15th Apr 2013 8:42pm
Natlas
Ken, I just saw your three symptom post. Mine has the first two symptoms, I haven't noticed any delay yet when pressing the throttle, fingers crossed!
John. 2.2 90 XS
88" Series One
Old Norton Smile
Post #227636 15th Apr 2013 8:45pm
Ken Graham
HI john ( and Rob ) not good news Sad apparently after the tamper proof bolts on the ECU put up a pretty good fight against the technician and kept him at bay for a few hours Laughing they managed to swap the ECU from another new Defender and then it was fully programmed the car is no better than before.
Looks like we have a serious technical issue and no one knows what it is .
Will keep you posted.
Loved the story about your Atlas John, my mk2a was destroyed unregistered in the Birmingham M/C Museum fire and is now recommissioned with just over 1000 miles on the road.
Cheer , will keep you posted.
Ken.
Post #228380 17th Apr 2013 11:34pm
LoveB
2013 Defender 110 Puma 2.2 SW Orkney Grey
Hey all, the delay is put there to 'help' you shift gears... however if you actually know how to drive this makes it a nightmare to shift. lol
Easy solution is to short the two wires going into the clutch switch which would then disable the revs holding itself. makes for an easier car to drive.
Post #228391 18th Apr 2013 4:37am
LoveB
Ps you can short it without actually leaving it unplugged. Just get a small piece of wire and put it between the two prongs then plug the connector back in. Voila. When you step on the clutch the revs will drop as they should. Goodbye crunchy gear changes
Post #228400 18th Apr 2013 5:33am
Ken Graham
Hi John , off on hols for a few days will give you an update on my return.
Cheers Kg.
Post #228749 19th Apr 2013 4:48am
Ken Graham
Laughing Ok guys here it is !!!!!!!!!
Main land Rover dealership has been told my L/R tech services to swap out the PCM and Alarm control module from their new 2.2 Defender that we know runs perfect ..... JOB DONE the dealership asks me to come in and test drive both car ....
The Demo car with my PCM drives perfectly , my car with the guts of the Demo still has the same symptoms .....
Back to square one we thinks ?????? NO ...... when my car is refitted with it's own PCM and alarm control module the garage does not test drive the vehicle -MISTAKE - TEMPORARY RESULT.... The Cars drives 99% easy gear changes, no surging , no excessive revs holding up YIPEE Big Cry No short lived ... 400miles later the fault returns.
What are we looking at ? is it a connection problem ? Lost for words and getting tired of Kangarooing about with little control over what the car wants to do Sad
Post #234280 9th May 2013 11:14pm
RobKeay
I had a problem with kangerooing in second gear. Land Rover have updated my ECU software. It still can kangaroo if I really force it. As far as I can make out its symptom of the engine learning what's being asked of it. The only time it does it now is if I've thrashed it to work because I am late. I then have to go up the drive at 5 mph the engine then starts kangerooing. If I then dip the clutch for a few seconds it goes away and settles down and will roll along in second gear with no revs.
With the holding of the revs mine will do this, again I make it do it.
Most of the time I change at around 2200 revs. The only time it holds is when i give it the beans and then wait for revs to drop it will hold the revs. But this is really a strange way to drive and change gear. If you want to get moving surely you will want to keep the revs going to match the road speed. If you let the revs drop down you will lose your momentum. I find with the torque coming in so low there's no need to rev the engine much. It's all electronic the accelerator pedal is a potentiometer so takes some getting used to.
Post #234315 10th May 2013 8:25am
Ken Graham
Cheers Rob
I.T. brains from L/R coming up in two weeks time, will keep you posted if they find a fix.
Thanks Ken......
Post #234322 10th May 2013 8:45am
Malcolm
South Africa 2012 Defender 110 Puma 2.2 CSW Fuji White
My 2.2 110 also held the revs. It disappeared after a few weeks (can't recall how many km's I had done at the time). Now the revs drop freely when changing gears.... Very strange. Ex 2008 Puma 90
2012 Puma 110
Post #234427 10th May 2013 6:13pm
Natlas
Hi All,
I'm still mystified but am learning how to live with the peculiarities of the beast Confused
regards,
John. 2.2 90 XS
88" Series One
Old Norton Smile
Post #234429 10th May 2013 6:25pm
mice72sg
Singapore 2012 Defender 110 Puma 2.2 HT Santorini Black
Hi All,
I am also experiencing this on my 2012 110.
It does give me a feel that I am driving a manual vehicle which behaves like an semi-automatic in between gear changes tho'... Rolling Eyes
I just had her for the past 5 days and will continue to monitor her behaviour for awhile.
However I do love the pull when I push her from 2nd to 3rd to 4th gear at times.
Even had a Ferrari driver glaring at me when my 110 suddenly overtook him while he was doing the cat-walk drive along a shopping belt.
Also the design is so so everlastingly alluring! Wink
The 110 seems to just naturally just "stand out" when it stops next to any car.
I am now sourcing for rims to replace my std issue 16" steel white ones.
Anybody able to recommend where I can purchase matt black 18" alloy rims at a reasonable price?
I will have to import them to my country though but that is not a problem as I am in the logistics industry.
Btw, I come from Singapore where it is almost flat everywhere so off road driving is out of my reach.
Tks ALL and Good to see ya! 2012 Defender 110 2.2L
Post #251667 16th Jul 2013 10:40am
RobKeay
Hi mike
Did I speak to you on talk land rover??
Post #251681 16th Jul 2013 11:44am
mice72sg
Hey Rob,
Yes sir.
I am the one who asked you regarding this rev issue.
Thank you for providing the forum details for me to join in.
After reading the post it seems that what my lady 110 is experiencing is similar to what other 110 owners have gone thru also.
At least I can understand now that my lady 110 is behaving kinda in line with the 2.2Ls.
Thanks Again and God Bless! 2012 Defender 110 2.2L
Post #251685 16th Jul 2013 11:54am
Page 3 of 4 <1234>
