Home > Td5 > morning all...
DefenderJay
morning all...
I lowered my 90 2, 1/2" and its got range rover sport wheels on running 275/40/20.. the drivers side wheels stick out more than the passenger side about 1" differents. I no you can buy a pan hard rod for the front but the back you cant do anythink about that... Does anyone know why they are sticking out further than the other side. Ive ask loads of people but they dont no why :(
Post #228050 17th Apr 2013 9:08am
Killer90
Site Sponsor
Jay- my Td5 done exactly the same thing mate Sad im not to sure what it is but perhaps the stops for your turning circle could be effecting it, unlikely but worth a play Confused CSK Automotive
www.cskautomotive.co.uk
Post #228055 17th Apr 2013 9:37am
DefenderJay
The back is the same chris something is pushing them out but what i dont no :-/
Post #228064 17th Apr 2013 10:08am
Porny
Site Sponsor
How would that even affect it? Please explain?....
Jay, the front is caused by the length of the panhard rod - you could fit an adjustable version, and realign the front suspension when at the desired ride height.
The rear is a bit stranger though - the rear axle is located centrally by the rear A Frame - so in theory the axle will only move up and down in one plane (unlike the front axle).
I would understand a twist (if you ever look at a land rover when cross axled, you will see that the rear axles 'walks' - highlighted more with extended suspension)...
Is the wheel perpendicular the rest of the car? - you could put a piece of string around all four wheels and look for gaps or ideally you need to go on a proper alignment rig. It is you then you have a misaligned chassis (damage or fault from new)... or even a faulty axle case.
If the wheel is on a twist (i.e. not 100% perpendicular) to the rest of the vehicle then you may have weak trailing arm bushes, weak A frame bushes etc. Or even one trailing arm longer than the other.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #228067 17th Apr 2013 10:19am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
defoo panhard rod for front Thumbs Up
could the brackets be welded in the wrong positions on the back ? 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #228068 17th Apr 2013 10:28am
big steve wrote:
defoo panhard rod Thumbs Up
Doesn't explain the back ....
Post #228071 17th Apr 2013 10:35am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Wouldn't be the first time, my 90 came from the factory with the rear trailing arm mount 1" further back on offside than nearside.
Post #228087 17th Apr 2013 11:40am
DefenderJay
I will take a couple of pictures when i go home tomorrow but the front & rear wheels on the drivers side are the same as they stick out an extra inch than the passenger side. Ive even had the hub converters off to see if they are all the same size and they are. Chris kill had the same problem when he lowered is blue 90..
Post #228158 17th Apr 2013 3:23pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
so.........................you was'nt right to go LOWER Putting Dreams on Drives at JLR Solihull..
Post #228355 17th Apr 2013 10:39pm
DefenderJay
I was lol i just got to sort the problem out ada or i will just live with it ;-)
Post #228437 18th Apr 2013 8:33am
