![]() | Home > Td5 > Replacing Transfer Box Input Seal |
Good afternoon Defender-ites. I am having a good news, bad news kind of a day today. The TD5 has just passed a sniff-test with flying colours and a coolant pressure test as well... Woop Woop no head gasket failure.
The garage did notice, however that the transfer box input seal is leaking oil down between the two gearboxes. Is this a DIY job? Does the box have to be dropped or can it be slid backwards and done up in the air? A mate and I put the box on about a year ago, it was originally off of a TD5 Disco, really regretting not changing the seal now... |
Cheers Jim. I am taking it the best way to do this is to remove the props, transfer brake, drop oil and remove the input gears as well to reduce the weight. Drop the box, replace the seal and refit carefully... |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
I wouldn't bother removing the internal gears, you'll only save a few kg and cause more work for yourself.
yes, props, handbrake totally (remove the drum then its 4 bolts),speedo drive, transfer levers (13mm nut on the difflock actuator and a clevis pin for hi/low), breather pipe, and the mounting rubber (only need to do the one that bolts onto the t/box) If you're strong enough, you can lift it down and back up again. It weighs about 50kg, so is a good little benchg press excercise, although you're limited in room to get full arm extension ![]() ![]() If you were so inclined, now would be a time to install a 1.2:1 box! longer legs. |
Oooo 50kg bench press ![]() ![]() Already got the 1.2:1 (Disco) box in the 110, massive difference for sure. I am wondering whilst I have the box out whether it is worth doing the output seals at the same time. In which case is it worth replacing the output flanges as well? |
