Home > Maintenance & Modifications > MUD DEFENDER ROOF CONSOLE
Page 4 of 8 <12345678>
Fitted mine on Sunday, and must say that I am impressed! The quality and fit are excellent, and in general it was very easy to fit.
I had two issues with the fitting, both connected with the self tappers into the doorframes, and would be interested to know if anyone else who's fitted one has had similar problems:-
1) The instructions say that the holes for the self-tappers in the door frame should be 4mm, but the first one I drilled at this diameter was too large, the screw simply pushed in and fell out. I ended up drilling 3.5mm which was a good fit.
2) To secure the console in position while drilling the holes, I used a G-cramp to pull it into the doorframe. Even so, if drilled vertically upwards all 6 of the holes missed the doorframe altogether, and the only way to find any metal to drill into was to drill at an angle about 30 degrees from vertical, outwards. This seemed to do the job (although it was very hard to avoid the conviction that I was about to drill out of the roof and into the roofrack foot!).
These two issues aside (and they're very minor), it is a very good product indeed IMHO.
Incidentally I didn't remove the two original "fir trees" holding the headlining into the door frame since I couldn't see any reason to do so. Leaving them in place didn't seem to cause any problems and I am really not sure why the instructions say that they shoudl be removed.
Post #227762 16th Apr 2013 11:16am
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
I was also a little baffled as to why those fir tree's above the door had to come out, I did remove them as they were step one of the instructions but I left the one out and refit the other Confused and I had to drill at an angle to find the frame Confused But, like you say, very minor issues and overall a good mod Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #227773 16th Apr 2013 11:58am
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Yes same here.
Leave the fir trees in place!!
Good product!!! I ran two separate 2.5mm2 ripcord cables to the top to fit additional electrics.
Post #228472 18th Apr 2013 10:32am
Naks
Marius wrote:
Yes same here. Leave the fir trees in place!!
Marius, do you have some pics please? How much did it end up costing, including shipping & taxes? --
Post #228528 18th Apr 2013 1:25pm
Marius
Cost breakdown:
MUD Defender Roof Console
Item# roof-con £132.50 GBP 1 £132.50 GBP
USB Socket x3
Item# USB £50.00 GBP 1 £50.00 GBP
Shipping
Item# Shipping Option - UPS Express £93.00 GBP 1 £93.00 GBP
Subtotal £275.50 GBP
Total £275.50 GBP
Payment £275.50 GBP
But I bought 3 USB car charger sockets as you can see. I only paid $20 Vat and clearance fees of that total you see there.
So we looking at £330 all in all at my door.......and literally it came to my door via UPS. R4552 in total based on what the exchange rate was at that time.
I say well worth the purchase!!!!
Post #228534 18th Apr 2013 1:40pm
Naks
Jah, looks well worth it. but we are building a house, so Crying or Very sad --
Post #228535 18th Apr 2013 1:42pm
paulmuaddib
Portugal 2001 Defender 110 Td5 HT Alpine White
Need an opinion from the guys that already have the mud console installed...
I'm a tall guy and when inside my Defender my head is about 1.5 inches away from the top of the car so when i look straight forward my view area is just near the top of the front windscreen. If I install this roof console do you think I will loose some visibility?
Thank you.
Post #253907 27th Jul 2013 10:39am
Merlin
I've fitted a MUD console and have no problems. I'm over six feet tall and have a seat lift of one inch as well. In fact as the sun visors are a bit lower it's better as there is less windscreen at the top to give glare.
If I were you, I'd buy it. It's a great piece of kit.
Merlin
Post #253919 27th Jul 2013 12:49pm
paulmuaddib
Thanks for the reply, Merlin...I think I will buy it indeed! Smile
Post #253950 27th Jul 2013 5:24pm
Merlin
Don't do what I did, fit it and then take it out to fit the CB. I found it best to cut the headlining and run wires before fitting the console. I poked a straightened coat hanger between the headlining and the roof to get the wires through and then ran them down B pillar.
I must say that MUD have done a wonderful job, many people think it's OEM.
Merlin
Post #254102 28th Jul 2013 2:50pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
I fancy one of these to house my Ham Radio head, even SWMBO thinks they are a great idea Bow down
There is talk in the thread about the rear washer feed pipe above the door and to be careful to avoid it. Without taking down the headlining (perhaps this is why the fir trees should be removed Question ) how can you be sure to avoid it?
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #254164 28th Jul 2013 7:42pm
Merlin
Didn't know about the pipe. Perhaps that was just as well. Thought there was a large 'wire' there but just worked around it. So, not a problem.
Merlin
Post #254300 29th Jul 2013 9:16am
ChrisCM
Well, finally got mine, arrived yesterday fitted this morning.
A few observations, you need strong thumbs to get the fir tree fasteners in!, I used a piece of 2x1 to push them in. When fitting the outer parts, if you are doing it alone, as I was, it makes it a lot easier if you temporarily duct tape the sunvisors to the moulding and use a drop of superglue to hold the spacer.
The instructions say that the door frame is tough to drill, it is! I broke 2 drill bits, I found that a 3.5mm drill, as advised by blackwolf was too small and I was unable to fit the screws without chewing up the heads, 4mm seems ok, maybe they've changed the spec of their screws ( which seem overly long?)
All in all I'm very pleased with it, it looks very smart, like OE. Now for the Ham Radio head unit!
Post #264234 6th Sep 2013 1:15pm
x-isle
As I'm now looking for a better place to put the CB, I've just taken the plunge and bought one.
Can someone who has one fitted let me know the rough height between one of the shelves and the headlining.
The reason I ask is I'm hoping to hide my CB's external speaker on top of the one of the shelves and the speaker I've got is about 6cm in height. I looks as though it'll fit ok from the photos. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #269712 27th Sep 2013 8:52am
ChrisCM
Hi Craig,
The hight of the shelf "orifice" is 50mm, the internal height is approx 65mm but this only goes back about 50-60mm (to allow for the sunvisor recess) and goes down to approx 50mm, so I think it may be a bit tight. An option might be to cut out a bit of the head lining or perhaps surface mount the speaker facing down inside the shelf?
Post #269729 27th Sep 2013 11:04am
