![]() | Home > Puma (Tdci) > How high do you rev your 2.4tdci?? |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Regular driving I change between 2,800 and 3,000rpm. If having fun I will take it up to about 4,000rpm.
If you check out the BAS rolling road maps you will see that power starts to drop off at about 3,700rpm and then hits the cliff at just over 4,000rpm. Powerband is about 2,400rpm through 3,700rpm anything over than and you are losing performance and it is pretty pointless (especially in Std map). *EDIT* Forgot to mention, Torque starts to drop off just under 3,000rpm, so yes, you get more power but less torque so you are fighting a losing battle after about 3,200rpm.* Glyn ![]() ![]() |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
2,000 rpm to 2,200 rpm 1982 88" 2.25 diesel
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20961 ![]() ![]() |
As above but occasionally hit higher if I need to momentarily I.e. having to pull out onto a fast road. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
I'm with Glynparry25.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
Me too, although I run standard tune. Anything over 3,200 and you're starting to waste your time. |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
+1 for Glynn. They aren't economical at the best of times, just drive it...... Makes a good bellow at about 4,000 after 4,500 starts to loose puff and sound a bit wheezy. ===================================
Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2676 ![]() ![]() ![]() |
Until the engine is warmed up properly, I do not rev past 2200.
After that, I give it horns, sometimes upshifting at 3500-4000rpm while gunning it uphill. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Baggie Austin Member Since: 16 Mar 2013 Location: Birmingham Posts: 102 ![]() ![]() ![]() |
I dont tend to go over 2500rpm
First90 Member Since: 20 Mar 2012 Location: Melbourne, Australia Posts: 22 ![]() ![]() |
Seems we are generally in the same boat. I will stick to my low 2's and give it a few herbs from time to time to blow out any soot...
Also that is a sweet looking rig Baggie.. |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 ![]() ![]() ![]() |
Generally between 2,200 - 2,500 and may hit 3,000 on the odd occasion
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Depends on what mood I'm in... and what is trying to keep up with a farmers spec Defender lol.
[URL=] ![]() Click image to enlarge[/URL] This is one of the last runs on the rolling - as you can see it pulls from below 1200rpm and then gives a good bell shape of power (bhp). My 90 in current form will rev to just over 4500rpm - with over 100bhp at wheels from 1870rpm to about 3500rpm (peak calculates to 176bhp at 3100rpm). In reality peak torque has come and gone - and we are talking diesels not petrol! However, the 2.4 is a very rev happy diesel (the 2.2 even more so as is virtually a 'square' engine').... my 2.4 is back on the rolling road soon with more to come. If we look at a Standard Defender 2.4 vs my entry level calibrations... [URL=] ![]() Click image to enlarge[/URL] We can see a similar shape - but a much flatter bell shaped. With the standard calibration at 3500rpm you start hitting the roll out into the rev limiter (where the fuelling is removed to prevent engine over speed), so not much point reving much harder - and you are only getting 90bhp at the wheels max (118bhp at the wheels).... and you only get 85 ish bhp from 2800rpm to 3500rpm. Ian Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2676 ![]() ![]() ![]() |
Normally I cruise around 1800-2200 revs in 6th.
I try & change up a gear as soon as I can, but without labouring it...Generally in the higher gears I keep it above 1700rpm unless downhill... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Thanks very much mate, just waiting for my clear indicators to arrive now ![]() |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
Max has been about 3200, smoother with better fuel. What mod is best at giving more torque at lower engine speeds? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
