Home > Td5 > Bit of Help with Radio Removal
FortySeven
Hello!
So after putting up with my lovely factory stereo for the last year and a half I figured it was time for a change. I've managed to get the radio out of the dash, however I've run into a problem actually removing the cabling from the back of the unit. Just can't figure out how it's done.
I've attached some photos below of what I'm up against. Anyone know how I can do it??
Thanks in advance.
A.
Post #227548 15th Apr 2013 7:05pm
Glynparry25
I have seen many plugs like that.
You stick the screwdriver in like as pictured and it slides up (this is a locking mechanism) - it looks like you have already done this?
Then you just prise the plug off the pinss- this will probably be stiff if it has been on for a while.
Glyn Dog Sheep
Post #227551 15th Apr 2013 7:20pm
mk1collector
The clue is in the picture on top of the wiring block. You prize the top up with a screwdriver, it's quite tight and must be lifted fully up before the block can be pulled away from the stereo. You will probably need a wiring adaptor if your putting a new stereo in too.
Post #227552 15th Apr 2013 7:20pm
mk1collector
Beaten too it by glyn Thumbs Up the locking mech does need to be pulled up further than you have it in your pic.
Post #227553 15th Apr 2013 7:22pm
FortySeven
Thanks Glyn.
mk1collector wrote:
........the locking mech does need to be pulled up further than you have it in your pic.
See here's where I'm getting stuck. The locking mechanism doesn't raise up any higher. One side is on two tracks with a pin/dowel of sorts that prevent it being lifted any higher. (can sort of be seen in the second photo)
I've tried to pull the plug from the socket but it's not moving at all. Clipping wires and creating a switch is far beyond what I can do so still trying to avoid that.
Post #227671 15th Apr 2013 10:58pm
mk1collector
If you prize up the locking tab and wiggle the wiring block at the same time it will come off, a bit of brute force helps Thumbs Up
Post #227678 15th Apr 2013 11:10pm
FortySeven
Turns out the trick was indeed brute force. Thanks for that. Now to find the right harness adaptor to make everything work.
This one looks almost right:
http://www.halfords.ie/webapp/wcs/stores/s...yId_212460
Post #227898 16th Apr 2013 7:50pm
mk1collector
If you go into halfords they have a book with the codes in matched to the car so it's easy to find the right one.
Post #227929 16th Apr 2013 9:22pm
