![]() | Home > Puma (Tdci) > cooling issues with lightforce 240 ? |
| rleslie Member Since: 10 May 2012 Location: Ellon, Aberdeenshire Posts: 128
Can someone point me in the direction of where to buy brackets so I can mount my lightforce lights under my A bar? Currently I have them mounted on the top of the A bar and it looks a little silly.
Cheers Richard |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Get some made. I did, look in my gallery and enlarge the photo.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| billewizz Member Since: 16 Sep 2011 Location: north lincs Posts: 68
Nail on the head |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
fyi
You can restrict the air flow that will end up increasing the engine temp and reducing performance. Take a look at the location of the numberplate on J-Lo. The fitting of the powerplant and the numberplate restricted the air flow resulting in the issues just mentioned. However these issues only occurred at high external temperatures, when loaded, climbing up hill at high altitude. Non of which will be found in the UK I removed the numberplate and all was fine. Click image to enlarge |
| All times are GMT |
