![]() | Home > Off Topic > Lister Junior stationary engines |
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
Try a local traction engine rally. They usually have a stationary engines exhibit.
...or buy a copy of Old Glory. Have you tried contacting Lister/Petter themselves? ![]() |
| ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831
I may do but it depends on what needs to be done.
| noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196
As you are in Cornwall any good (old) boat yard will be able to point you in the right direction of where to get them re-metaled and then broached back to size. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Falmouth Dockyard. A & P.
http://www.ap-group.co.uk/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630
I used to work on Canal boats, full of old Listers. If you have no joy, give me a shout, I'll see if I can help.
