Home > Td5 > Defender TD5 flat spot woes and power loss! Please help!!
Alastaird
Hi all,
This is my first post in the forums wondering if anybody can give me a hand. I'm a med student from Notts with a 2001 defender td5
To cut a long story short, I had terrible cold start acceleration performance. 2001defender TD5 Car was a menace to pull out into the road as took good 20 sec to get any sort of acceleration or power....
Anyway I unplugged the MAF sensor and immediately got unbelievably good performance - best ever so far with my landy.
Concluded was MAF problem as have already blanked off EGR months ago.
Bought new expensive genuine LR MAF and fitted it. When Plugged in the acceleration problem is even worse... there is a massive flat spot at low RPM's takes about 30 sec for any sort of power to develop... truck is undrivable with it plugged in.
I'm thinking this is an airflow problem?? APP sensor?
Does anyone have any ideas about what to do next? I finally thought I was going to get a few trouble free months with the landy but it thought otherwise....
I've just cleaned out the MAP sensor this morn and had no effect...
Thanks so much in advance for any help!
Hope everyone's had nice weekend
Alastair
Post #227125 14th Apr 2013 12:29pm
barbel jim
Unfortunately sometimes they fail straight out the box Big Cry I would take it back and swop it for another first.
Post #227127 14th Apr 2013 12:34pm
K9F
As your symptom actually worsened with the MAF sensor swap out I would agree totally. Do you know anyone else locally with a TD5 that you can do a 'diagnostic' swap with the two sensors you have or 'borrow' theirs to fit to yours perhaps? Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #227128 14th Apr 2013 12:38pm
Alastaird
ok thanks for your quick responses!
Will email the company tomorrow. it was from Island 4x4 so will have to speak to them
Assuming the MAF is fine what else could it be? It's been suggested blocked air hoses ect?
So frustrating!
Post #227137 14th Apr 2013 1:08pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
I would get a replacement MAF sensor first to sort the main issue.
Then if your still not sorted I would look at:
- changing air hoses (at higher speeds if the TD5 hoses have delaminated they can collapse, so take off to see if delamination has occured)
- cleaning the MAP sensor
http://www.landyzone.co.uk/lz/f67/removing...98286.html
- stuck waste gate actuator (like hitting a power wall, for me at about 60, with no acceleration possible on any incline)
http://www.youtube.com/watch?v=FyZ4zXPZOf8
Post #227169 14th Apr 2013 5:05pm
barbel jim
So frustrating!
Is your landy standard? If it has been hoped up with a larger intercooler and running more boost sometimes a standard maf cannot cope with the amount of air flow Thumbs Up
Post #227242 14th Apr 2013 7:18pm
Alastaird
No completely standard... I've removed EGR that's it.
So took to local garage who cleared all fault codes with new MAF.
Car starts and runs fine BUT absolutely no low end grunt. Once turbo kicks in its absolutely great.
Is there any way of making the turbo kick in any earlier?
(garage tested the MAF and said it was fine...
Is there a way of adjusting waste gate actuator arm length for example (worried to touch it Shocked )
Thanks for any help!
Post #227549 15th Apr 2013 7:06pm
You can adjust the waste gate actuator arm (shorten it to give more boost) but without a "boost box" to mask the extra pressure from the ECU, you'll just go straight into limp home mode. plus without any extra fuelling you'll get no more power anyway.
Post #227559 15th Apr 2013 7:49pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
Also may be worth checking / cleaning the fuel filter. My Td5 was really sluggish on acceleration, especially 40-60, and sorting the fuel filter helped a lot - drove like a different vehicle. Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #227648 15th Apr 2013 10:30pm
bell-auto-services
I have hadthese airflow meters in the past and for some reason as said have failed straight out of the box, i know it states OEM but i do have my suspections as to if its EXACTLEY the same as OEM or just made at the same factory?
http://www.island-4x4.co.uk/flow-sensor-mhk100620g-p-3943.html
As diesel-jim stated you could also have a sticking turbo wastegate so thats worth a checkafter the maf is verifyed.
You can measure the output from the maf with a multi meter as a simple testif you can get hold of one? 2Vout from the miiddle pin with the engine running and while it still connected to the car is 60kg/hrof air which is perfection, much less than 1.7V and its about dead.
Pete
Post #227656 15th Apr 2013 10:41pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
here ya go Alistair.....  Putting Dreams on Drives at JLR Solihull..
Post #227660 15th Apr 2013 10:45pm
landy andy
I'm in Herts and got a MAF if you can get here for a test? But personally just send it back as faulty. Other faults won't be altered by unplugging/plugging the MAF, so will be MAF issue.
I use uprated MAF's from alive tuning. Last much longer.
Andy
Post #227709 16th Apr 2013 7:35am
Laurie
I've had the same problem for several years.
Sometimes, when I start it and drive off, there is no power for several seconds, then it suddenly hits you in the back and zooms away.
Most times it's perfectly OK.
It doesn't make any difference whether the engine's hot or cold.
I've just learned to live with it.
Post #227754 16th Apr 2013 10:53am
robk
Netherlands 2002 Defender 110 Td5 SW Epsom Green
And.... how was your problem solved?
After reading this interesting thread, i concluded I have exactly the same problem.
I am curious how this problem eventually was resolved?
KR
Rob
Post #487070 30th Dec 2015 10:57pm
excossack
I too have a similar issue (1999 td5/10p engine). Just as a matter of interest, when you press the throttle pedal, how far do you press it before you notice revs picking up? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #487162 31st Dec 2015 9:42am
