Home > Camping, Caravanning and Holidays > Tow ball question?
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Tow ball question?
I have a factory fitted Land Rover tow bar fitted with a standard tow ball and hitch that I use to connect a tow rope to, when needed. Modern caravans use the Alko stabiliser system with a long neck tow ball. Does anyone know of a Alko type tow ball + hitch that I could fit that is compatible with with the Alko stabiliser system yet retain the hitch for safe connection of a tow rope? Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #226643 12th Apr 2013 6:07pm
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
Hi, we have the LR standard tow bar / tow ball and use the ALKO AKS 3004 stabiliser hitch with no problems, it looks very close but there is just enough clearance to allow the hitch head to move freely. Remember to degrease you ball properly
Rolling with laughter Rolling with laughter before attaching you tin tent.
Forgot to say, you can get a spacer plate (approx 3/4 inch thick) for the tow ball with slightly longer bolts which enables the use of almost any tow hitch. You only have one life, live it....forget the cost.
90XS Hardtop
Post #226650 12th Apr 2013 6:21pm
WelshGas
Thanks Sonarmender. Further research shows that Dixon Bates make a combined Alko Tow ball and hitch. The Alko ball has a longer neck 60mm from base to mid ball to allow the deeper Alko hitch to articulate side to side without hitting the neck base. If it cannot do this then it can be forced off the tow ball and unhitch the caravan. This wouldn't normally be a problem on smooth road surfaces but with the state of our roads, nowadays, and using CL sites etc: which could have less smooth ground then it could be a problem. As my present tow hitch is also painted - a no go for the Alko system, I will get this Dixon Bates hitch.
http://www.bradleydoublelock.co.uk/shop/product.php?xProd=2816 LANDYWATCH
Post #226787 13th Apr 2013 10:37am
WarPig
^^^Thats the one im after, once I've saved up enough coins in the 1p jar Smile
I currently use a standard alko tow ball on and adjustable slider. If you haven't got the adjustable tow assembly then check the Bradley alko hitch isnt going to be too high for your caravan to remain level as I guess the towball will be slightly higher than standard? Its worth getting the alko version so the friction plates can grip properly to the ball.
Post #227171 14th Apr 2013 5:10pm
WelshGas
Towing vehicle - floor to midpoint of tow ball head should be 385 mm +/- 35 mm according to EU regulations. But the regulations DO NOT state if these measurements are with a laden vehicle. I had no problems towing in the past with 110's, the rig was level when the vehicle was loaded and caravan connected. My measurements at present show the height from floor to mid point of ball is 445 mm with an unladen vehicle, so I think things should be OK when the 90 is loaded and a 100 kgm nose weight of the caravan. Wink LANDYWATCH
Post #227247 14th Apr 2013 7:22pm
WarPig
Lorryman has had a few different brands of alko tow balls, cant remember which one he preferred though.
Post #227283 14th Apr 2013 8:24pm
JSG
Dixon Bate hitches work well for fitting recovery straps to as well as towing.
The Alko hitch has a longer neck, the similar Winterhoff hitch works without needing the taller neck.
http://www.bradleydoublelock.co.uk/shop/pr...58837c26c3 John
2011 Tdci 110 CSW XS
Post #227328 14th Apr 2013 10:13pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
"My measurements at present show the height from floor to mid point of ball is 445 mm with an unladen vehicle"
Just popped outside to check mine, about the same, perhaps a little more; I tow a large boat on a twin-axle trailer, the rig ends up perfectly level, so that height can't be too far wrong.
Peter
Post #227481 15th Apr 2013 4:27pm
WelshGas
Thanks all for your advice. Thumbs Up LANDYWATCH
Post #229735 22nd Apr 2013 9:00pm
roamingman
I do not think it is a good idea to put a rope on to a tow ball. very easy to slip off. Smile Live Life Ti'l You Die
Teddys are out thier
http://teddybearspicnic.webs.com
http://130sasha.co.uk/
Post #229831 23rd Apr 2013 10:16am
J8GHX
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Are you aware that Dixon Bate make an Alko / Winterhoff compatible extended neck tow ball and jaw combination?
Surely that would be the answer?
http://www.bradleydoublelock.co.uk/shop/pr...425967f3ee
John Currently....... all gone...... pending delivery of a mid life crisis.......
Previously..... Quite a few! I really am a sucker for them!
Post #230591 25th Apr 2013 11:33pm
leeds
Tow balls are not designed for shock loading.
IF you are going to use a tow ball as a recovery point then use a bungee to keep rope on it.
Brendan
Post #230592 25th Apr 2013 11:39pm
JSG
John
Indeed, as I posted above Thumbs Up John
Post #230650 26th Apr 2013 11:31am
