![]() | Home > Off Topic > Harrogate Car Parking |
| Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226
Last time I was there I parked on street in one of the little residential estates to the NE of the centre. There usually are some spaces around and about. Every time I've been recently the main multi-storey has been full by the time I've got there. Probably not as issue if you're exhibiting and arriving early. Don't know about the height restriction in the multi-storey I'm afraid. 2005 Td5 | 90 Station Wagon | Tonga Green
| lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006
I'll have a look tonight after work and let you know. Rhubarb and custard let fly with their secret weapon.
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
Green Machine- I'm not planning on being there too early, I'll arrive fashionably late
Thank you, much appreciated "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
2.00m Rhubarb and custard let fly with their secret weapon.
Thank You "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| Small Clanger Member Since: 22 Jun 2011 Location: UK Posts: 210
I usually park at the Tower Street pay and display (which is opposite Tower Street multi storey) and usually has spaces. It is behind the Coach and Horses pub on West Park- HG1 1BJ - It's also on the right side of town if you're heading in from the west side or A61.
A few minutes walk down West Park and Parliament Street takes you to the Conference and Exhibition Centres. |
Thanks, I'll bear that in mind. I'm rather hoping that it'll fit in the exhibition centre car park, but failing that I'll implement yiur idea "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169
I think the surface level car park on Tower Street (but called West Park) is only a short stay of 4 hours so if you are going to be all day at the HIC that may not work.
For surface level car parks, including charges and lengths of stay check out this link http://www.harrogate.gov.uk/prkg/Pages/Car...Level.aspx Unfortunately Harrogate Council doesn't give height restriction info on its website, which isn't at all helpful! The Surface level car parks should be fine as, AFAIK, none of them have overhead barriers. One of the closest surface levels to the Conference Centre is Park View - it is 24 hour and mid-priced, and is usually fine for finding a space most times. Our blog - http://landytravels.com/ Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
| All times are GMT |
