Home > Puma (Tdci) > need help removing standard radio
hi i'm new on this forum and i recently got my new 90 puma but i wanted to remove my standard radio however i have found this to be more difficult than i imagined Sad i have tried all sorts exact fitting wire in all for holes moving it about ect and i've also tried allen keys however nothing has worked and also i would like a bit of acess some how to the back as my new radio has plenty of wiring to place. any ideas?
thanks
Post #22603 21st Jan 2010 1:15pm
scatt
England 2008 Defender 110 Puma 2.4 DCPU Alpine White
You need to buy some radio keys, either from halfords or a car audio shop.
Post #22618 21st Jan 2010 3:46pm
i will buy some universal ones tomorrow and try that
Post #22657 21st Jan 2010 9:49pm
K9F
Radio Removal!
I recently fitted spotlights to my Defender, with the wiring fit I too needed the radio out to facilitate the switch fitting and wiring. I just popped along to my local dealers and asked if they would release it for me which they did! In fact they were only too happy to oblige! Even with the correct tools it was still a pig to release it! When finished it just slid and locked back in place.Wecome to the site by the way.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #22688 22nd Jan 2010 10:54am
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Radio Tool
Hi,
You will need a pair of 'U' shaped wire tool (similar in thickness to clothes hanger) which has a pointed and grooved tip and insert one on each side (it needs to be inserted with some effort, but no force) once the tool is located move the tool side to side with some tension - it will slowly pull out! (remember to pull on the tool side to side). There is room at the back to access the wires,etc. But the radio is a tight fit and the wires are not very long. Replacement - insert the radio all the way till you hear a 'click'.
The tool you can get from any motor factor (Don't know whether Halfords will have it?) but motor factor will.
"El pepe flamenco" Cool JLS
'El Pepe Flamenco'
Post #22718 22nd Jan 2010 3:54pm
thanks for your help lads i got some universal radio keys from Halfords today and they done the job perfect Thumbs Up Mr. Green Thumbs Up
Post #22738 22nd Jan 2010 9:20pm
