![]() | Home > Technical > Wheel Replacement |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
few thoughts...
* you dont need 8j rims for 265 tyres. a 7j rim will be fine which will likely improve turning circle. * if you have +35 rims even on 7j they will stick out at least 25mm beyond the standard arches, look stupid and require extended arches. * im assuming you have played about with your lock stops. |
I run 285/75 BFG Muds on boost rims (same offset as yours afaik) on 30mm spacers on my 110 and have no lock issues at all, it turns better than my Disco 2 (not that that is particularly difficult). I don't understand how you can be having issues with 265/75s unless your lock-stops or your expectations need adjusting!
If you move your tyres outwards any more, at least by any more than 10mm or so, you will need to extend the arches. Mine are absolutely on the limit of legality. Check your lock-stops first. |
Andy Jeff Member Since: 11 Nov 2012 Location: Suffolk, UK. Posts: 143 ![]() ![]() ![]() |
Maybe I should have said that I whilst the lock isn't 'bad' as such, it's not as much as it 'could' be. Yes, I've adjusted the lock stops, but the tyres are catching on the radius arms and I still have plenty of lock stop (and swivel hub) to go. The car is used for trialling and most other competitors are beating me because of their tighter turning circle.
The reason I mentioned 8j rims was because (without too much of an in depth look) the only decent offset rims I found were 8j's. I know I'm lazy. I should have mentioned that I'm au-fait with the mechanical side of thing, and completely understand the setup of the components involved. My last trialer (a 300tdi 90) ran the same size tyres (though they were BFG KM2 muds) on modulars, but the contact profile 'on the road' is way different for the special tracks. Remembering that because this is a car for trialing, it means that I want the absolute maximum lock possible. I know I could go for skinny wheels/tyres, but I want to get the maximum out of what I've got so to speak! What I don't want to do is spend a couple of hundred quid on rims and getting the tyres fitted just to find out there's no advantage. Hence the concern that neutral rims and removing the spacers wouldn't give me anything over the current setup! Andy. |
Ok, clearer now. For trialling you might be better off shifting the tyres outwards either with wheels or thicker spacers, since arch protrusion isn't a legal issue provided you're driving somewhere the RTA doesn't apply, and can pass scrutineering. Change the wheels or add the spacers on arrival, change back before leaving, assuming you're in an RTV class and not trailering.
Be careful though that there isn't a risk of the tyre impacting the arch on extreme articulation. Alternatively fit fiddle brakes with a lockout for road use. Don't forget to check the current specs since there's no point doing anything that won't pass scrutineering. |
