Home > Maintenance & Modifications > DIY clutch change on td5 90 recommendations / help needed
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
I will soon have to replace my clutch and possibly flywheel on my td5 90. I know this because I can make it slip while towing heavy loads.
I'm considering doing the job myself, not because I want to save the money but because I get a lot of satisfaction from doing such things Smile
If we're to do this I would have to do it on my driveway with the use of trolley jacks and possibly an engine hoist.
I'm wanting to know how feasible is this, I've not done any heavy work like this before, but would have a mate to help me.
Is it best to use combination of trolly jacks / engine hoists to move gearbox back or remove engine.
Any top tips would also be appreciated
Does anyone know of any online guides for this job please.
Anybody local (midlands) have an engine hoist I could borrow / hire?
Thanks in advance for your help Thumbs Up
Post #225725 9th Apr 2013 9:25am
Accepted practice (and the dealer method) is to drop the box out. This is in most ways the easiest and quickest way to do the job, but the problems in the DIY driveway environment are (1) getting the vehicle high enough to drop the box, and (2) managing the weight of the the complete gearbox/transfer box assembly.
It is possible to handle the box safely either by fabricating some sort of flat base which bolts on to it so a jack can be used (the dealer method), alternatively an engine hoist through the cab door supporting the box with slings (after removing the seat box panels and floor panels) works.
The main advantage of taking the box out is that noneof the engine connections need to be disturbed, and, if you have it, the AC doesn't need to be emptied and refilled.
Since the TD5 has a dual-mass flywheel you probably want to replace it at the same time as the clutch, and I would also change the slave cylinder whilst you have the box out.
It is actually not a difficult job, just be careful not to get under the gearbox - it is quite heavy enough to kill you if it lands on your chest!
Post #225740 9th Apr 2013 9:57am
amondeggs
Ok and thanks for your reply Thumbs Up
I was thinking of the engine hoist through the door method tbh.
I have 2 car ramps and was thinking of getting another 2 to get a bit more height on the driveway. I think the engine hoist method would involve some work to remove the seatbox and floor panels but would be safer than trying to balance the gearbox on trolly jacks.
Thanks again Thumbs Up
Post #225744 9th Apr 2013 10:03am
Porny
Site Sponsor
If it was me doing it on the drive...
I would take the engine out if you have a engine crane.
A perfect excuse to the give engine bay a proper clean, and new anti freeze etc etc.
Intercooler, radiator out, exhaust down pipe off, remove the engine mounts - really not a bad job to do, and IMHO easier than struggling on your back to get the gearbox out.
Don't be tempted by a cheap clutch use a Valeo Clutch and flywheel, new flywheel bolts etc.
You will have the engine out in a couple of hours...
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #225746 9th Apr 2013 10:04am
amondeggs
Engine out method also makes sense but I was reluctant to go down this route as I did not want to disturb the engine and cause other possible problems?
Getting rad and intercooler out will pose no problem as I have just replaced both Whistle
I may be worrying too much?
Post #225749 9th Apr 2013 10:12am
excossack
When I did with mine with help from a mate we dropped the box onto the x-member behind the box and slid it back on this. This gave us enough room to remove the DMF etc and change the clutch.
We undid some of the floor screws as well and the g/box tunnel.
Mind the wires on the g/box t/case and the crank sensor. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #225755 9th Apr 2013 10:16am
amondeggs
Ok thanks for that Thumbs Up
Just another thing,
The flywheel how will I know if it needs replacing?
Is it about the amount of play there is ? If so how much is too much? Is is it the case of replace it anyway as you have gone to all the trouble of getting to it?
Cheers Thumbs Up
Post #225759 9th Apr 2013 10:30am
excossack
I had the same thoughts, and thought sod it, I am doing the clutch so will do
DMF along with new bolts
Friction plate
Pressure plate
Release bearing and plastic clip thing
Clutch Arm
A bit more expensive, but its done now for another load of miles.
There is a specific torque for the bolts and done in two stages from what I remember. 1999 Defender TD5 110
Regards
John M0VAZ
Post #225761 9th Apr 2013 11:11am
with just a crane, I'd do as Ian suggests, engine out.
I had to whip the engine out of my 90 the other month (long story... when I built it I put the clutch plate in back to front so it wouldn't disengage... Rolling Eyes Embarassed Embarassed Embarassed )
I already had the coolant pipes disconnected, but that's a 10 minute job anyway, so it took me about an hour and half to get the engine to a "ready to lift out" stage, I unbolted the PAS pump from the block, leaving the pipes connected so that saved messing with that.
disconnect battery cable, fuel pipes (clip off, easy) a few other little bits, and by unclipping the main loom from the back of the engine, there is enough slack to lift the engine and rotate it about 40 degrees so you can lean over the wing and do the clutch work.
Post #225790 9th Apr 2013 2:16pm
amondeggs
Hi Jim and thanks for the info Thumbs Up
It certainly would save wrestling with the gearbox underneath the truck, also like the fact that you did not need to completely lift out the engine, great idea Thumbs Up
Thanks again
Post #225797 9th Apr 2013 2:59pm
whelo
Wales
I did my mates clutch couple weeks back, we done it from underneath.
I took the transfer box off then the gearbox, its only 6 bolts & couple clips to remove the transfer, with that out of the way the gearbox is easier to handle.
I put the front axle on stands & had plenty of room to get in there.
& with flywheel, there's plenty of video's on youtube with the amount of play in the dual mass..
Jason Getting there, slowly..
Post #225937 9th Apr 2013 9:05pm
amondeggs
Jason
Cheers for that, did you use trolly jack to move gearbox back?
Will have a look at you tube vids Thumbs Up
Post #225957 9th Apr 2013 9:46pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
I can't help with a hoist or anything like that Steve but if you need a hand (and I'm not at work when you do it) let me know and I'll pop over. Thumbs Up
Post #226041 10th Apr 2013 12:42pm
