![]() | Home > Puma (Tdci) > 2Q's. |
I'm pretty sure that the jets are
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Yes. |
You can get stainless ones on eBay ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
And from Mobilecentre. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Good info guys... Fitted the new jet with a tap from a rubber hammer and fitted chromed ring from GEMM Larbert. 30m max. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
The jets are a really tight fit ![]() But shout it at them in German because life is also terrifying and confusing... |
Not tight enough to stop them popping off when frozen. Quite handy the jet comes seperately now. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
NO! they are not the same on the inside! The rear one is shorter.
Stainless headlamp rings are available from us as well. WANTED: SII or SIII in max 1.5k |
I only bought the twin jet part not the threaded part with the brass nut, I never knew the parts came split. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
did not know that as well
![]() SII or SIII in max 1.5k |
Yes, genuine LR part too. I always felt separating the jet from the stub made it looser. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
I originally knocked mine off with a brush at tnhe jet wash. I stuck it back on with a smidge of marine sealant many months ago, seems to have done the trick as it's still there.
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
