Home > Puma (Tdci) > LED indicators
dudley472
United Kingdom 2009 Defender 90 Puma 2.4 HT Keswick Green
LED indicators
i've just ordered some LED indicator bulbs, has anyone fitted any, do you have to change the flasher unit ??
Post #224770 5th Apr 2013 8:35am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Yes, mobile centre one worked for me
Post #224784 5th Apr 2013 9:48am
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
...but you'll lose the trailer repeater indicator on the dash...
Pete
Post #224879 5th Apr 2013 4:30pm
ericvv
That's correct, and with the Mobile Centre relay you also loose the audible turning signal clicking sound. Can live with these two things, but still would be interested for a turn signal relay for LED turn signals which would have the audible signal too. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #225010 6th Apr 2013 2:50am
You could possibly fit a motorcycle-type bleeper for an audible warning.
Post #225017 6th Apr 2013 7:14am
LR90XS2011
or any 12v sounder from maplin DEFENDER 90 TDCI XS,
Post #225018 6th Apr 2013 7:40am
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
I fitted the RDX type from Bolt on Bits that comes with a replacement relay. Works with trailer and makes a noise. The way I understood it was that replacing the bulb in a standard holder with a LED type was not legal and should be a an MOT failure, correct me if I am wrong.
The RDX ones are standard looking and E marked, I fitted these to my previous 110 and was the first thing I changed on the new 110. 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #225022 6th Apr 2013 8:07am
landy andy
As above. I fitted the RDX led lights and relay, and when I connect trailer I still get warning light as it should be on the dash, whilst indicating. I even brought two led bulbs to fit to the trailer, as I thought that them being non led would cause probs, but they were not needed.
Andy
Post #225031 6th Apr 2013 9:10am
Wangers
United Kingdom 1995 Defender 110 300 Tdi CSW Aintree Green
Swollock is correct:
Fitting an LED bulb into a candesent holder is illegal and as such should fail an MOT )and even if it passes Mr Plod can still take you off the road).
Buying a specifically made LED light system is legal, and when fitted is also legal as long as it is E marked.
I bought a complete RDX kit and got Killer90 to fit it - perfect job, all work brilliant and legal.
The flasher relay will need changing as LED's inly deaw a tiny amount o power and as such with a niremal relay it thinks that a bulb has blown due to the less drawn power and goes into rapid flash mode.
RDX relay compensated for this and yes the trailr light is perm illuminated but flashes when i hitch a trailor, but still have the tick tick of an indicator.
It IS slower than a normal indicator but regs state that indicator must flash between 60 and 120 times per minute, RDX flashes as 63 per minute so is at the slowest end of legal. Broken bulb mode of a normal relay is around 160 - 180 per min hence is obvious.
So don;t get the bulbs get a kit (plently of varienty available) and keep yourself on the right side of the law.
As a fleet manager I have to know these things. TY&GN
10 years in a WOLF, WIMIK and Snatch and this is all I have to show!
Post #225038 6th Apr 2013 9:52am
landy andy
Wangers wrote:
RDX relay compensated for this and yes the trailr light is perm illuminated but flashes when i hitch a trailer.
My trailer light is not perm illuminated, it works as it did before, flashes once, as you put indicators on, then no more unless trailer is attached. Or have I misunderstood your post?
Andy
Post #225041 6th Apr 2013 9:58am
Wangers
Andy, you have understood correct. When running the trailor light is perm on and the normal one flashes, when attached to trailor both flash.
Right or wrong not sure - will find out in July at the MOT! TY&GN
Post #225124 6th Apr 2013 8:25pm
Green Machine
I thought the RDX relay had an adjustable flash speed with a small knob to change the speed? I seem to remember reading the set up instructions for a relay where you had to turn the knob until the indicator was on constantly, then just back it off a bit, or something along those lines? Could be wrong though! 2005 Td5 | 90 Station Wagon | Tonga Green
Post #225127 6th Apr 2013 8:33pm
landy andy
That was my understanding, you turn adjuster so trailer light just turns off.
So it should not be perm light, try a slight adjust
Andy
Post #225130 6th Apr 2013 8:36pm
Wangers
1989 to 1998 model says to install, turn on hazards and turn till light stops flashing (both sides of "not Flashing" are "fashing") so choice is either flashing or steady on.
Then turn hazards off and is set.
Will dbl check with RDX and see what they say.
Not a hastle having it on... TY&GN
Post #225132 6th Apr 2013 8:45pm
LR90XS2011
from B on Bs e/bay info
Bolt On Bits have been busy again developing the only proper 4 Pin Flasher Relay for Land Rover Defenders.
Bolt On Bits present: RDX 4 Pin Flasher Relay
No other company will offer you this RDX product.
You got LEDs you need RDX 4 Pin Flasher Relay
The RDX Relay that powers OUR RDX LED Standard Lamps!
A British company, A British design, A British product, for A British Car!
Why fit load resistors they defeat the whole object of less power. With our RDX LED Flasher Relay your Defender no longer needs Load Resistors!
A Standard Flasher Relay works on load, this means it is designed to see 21 watts bulbs, when you fit LED lamps or bulbs the Relay can not detect the load as the LED lamp/LED bulb may only use 2 to 3 watts, resulting in fast flashing which is no good to anyone.
So people fitted load resistors to imitate the load of the incandescent bulbs they have just removed, resulting in more wiring, things that get hot, melt anything near them and the best bit you are using more power than a standard bulb set up!
Then came LED Flasher Relays
Many have tried and failed but we haven't!
These often only could handle 30 to 40 watts which is fine for all LED vehicles but as soon as you put a trailer on it would blow or the user would fit the relay with bulbs and blow the LED Flasher Relay.
Some have tried to create a 4 Pin Flasher Relay but they state it might put the trailer light on when you are not pulling a trailer plus it can only handle 40 watts ours can handle 140 watts ha ha we win.
RDX 4 Pin Flasher Relay can handle bulbs, LEDs and a mixture of both on the vehicle it does not care it just gets on with the job!
The RDX 4 Pin Flasher Relay blows others in to the weeds, why as ours is tuneable this means it can be adjusted to suit your vehicle by simply turning the adjustment knob on top of the RDX 4 Pin Flasher Relay.
MOT law changed resulting in the trailer light must flash when a trailer is connected and the indicators/hazard is used. The MOT station can now test the towing socket if fitted!
Other Flasher Relays cannot detect a trailer has been connected which is now a requirement.
Now for the OCD ones
Have you noticed when you indicate the trailer light may flash once even when you are not pulling a trailer, well most other normal cars do not put a trailer light on for one flash. Tut tut Land Rover. Well ours puts the trailer light when you are actually pulling a trailer. When you are driving without the trailer and you indicate the little trailer light will not flash.
The trailer must be using incandescent bulbs or LED lamps with load resistors for the Trailer light to flash. It cannot detect trailers solely on LED lamps it will make them flash ok but will not flash the trailer light as the extra load is too little to detect.
The competition still offer load resistors we have moved into 21st century offering you bespoke products especially for Land Rovers because we drive Land Rovers!
The Flasher Relay is in three locations depending on your Land Rover Defender 90/110
Fitting: 1983 to 2001
2.5 NA, Turbodiesel, V8, 200Tdi, 300Tdi, early Td5 (no posh centre console models)
Fit LEDs to vehicle
Remove two knobs securing fusebox cover
Remove fusebox cover
Put hazards on if need locate second from left black relay
Remove relay and say bad relay
Fit RDX 4 Pin Flasher Relay
Turn ignition on, indicate left or right you chose
Turn knob on RDX 4 Pin Flasher Relay until Trailer light is flashing now turn back slowly until trailer light is not flashing.
Turn ignition off
Refit Fusebox cover
Refit two knobs
Fitting: Later Td5 2001 to 2006 (Posh centre console models)
Fit LEDs to vehicle
Remove 4 screws securing Instrument surround.
Lift Instrument surround up
Put hazards on if need locate black relay on far right
Turn ignition off
Refit Instrument surround
Refit 4 screws
2007 onwards Tdci (2.4 & 2.2)
Fit LEDs to vehicle
Relay is located under dash driver side
Turn ignition off
Info on DRL
The UK have not accepted DRL lamps they are not a legal requirement, ALL new Defenders are commercial vehicles thus making them exempt from DRL until the law is changed it may be legal in Europe.
They can be retro fitted to any older vehicle provided they are wired correctly. The DRL should be wired so the DRL is on when the engine is running many take a feed from the ignition but for the OCD ones it should be taken from the ignition & oil pressure switch via relay if you want to know when the engine is running. The DRL must turn off when sidelights are turned on. This is only a guide if you need clarification please consult with your insurance company. DEFENDER 90 TDCI XS,
Post #225136 6th Apr 2013 9:16pm
